View Full Version : Spartan wire drives
Jeff Wohlt
07-08-2011, 12:02 AM
The 078 wire drives are about to finish production so they will be shipping over the next few days. Please give us input when you run them. Hope they do well. Should run in the stock teflon just fine.
My aplogies for some of the wait but between the Holiday and me being glued to the hotel I have been behind.
dag-nabit
07-08-2011, 06:50 AM
Excellent, I have been very interested to try and run one of these.
Kevin
Snowride
07-08-2011, 12:01 PM
What exactly is needed if converting to wire drive?? What are the main advantages??
Jeff Wohlt
07-08-2011, 12:13 PM
Smoother, less friction, less maintenance, Does not compress uder torque (but still leave a slight gap at the strut), lighter, Will hold up better than a 150 cable. Does not suck water up like a cable.
Snowride
07-08-2011, 12:32 PM
So does this mean if I order one it will fit without extra parts or modification? Last time I ordered a wire drive I found out when installing I needed a new nut as the threads were different from stock and I needed to grind down the area where the set screw sits. Love your flex drive by the way, has been great with about 20 sets of batteries run through it so far.
Jeff Wohlt
07-08-2011, 06:15 PM
You need a 3/16" drive dog and nut for 10/32 threads...which is the std. Thank you for the compliment.
mtnbiker94
07-08-2011, 08:43 PM
Ordered mine last night, along with the Octura Coupler, and Octura Prop nut. Can't wait to get! I'll let you guys know how it runs when it gets here!
ebomb
07-09-2011, 05:24 PM
this is good to hear, as i ordered the wire drive last weekened and havent gotten any shipping info yet, doesnt matter any way as i sent my electronics in to traxxas anyways
Flame On
07-11-2011, 06:17 PM
Hey Jeff, I ordered everything via your site on Friday but on the Pay Pal site when I hit submit with all my payment info in place, the page just refreshed and cleared all the fields. I can't tell if the order went through or not. Afraid to do it again just yet. Sent you a email as well asking if it came through on your end. Hadn't heard back from you yet. Can you let me know if I need to try again or not as soon as you can? Thanks. Chris
Jeff Wohlt
07-11-2011, 11:06 PM
Chris, I do not see anything. I have gotten orders even last night.
Flame On
07-11-2011, 11:08 PM
okay, i'll do it again tonight. Thanks.
Flame On
07-11-2011, 11:30 PM
Done... went through that time. Let me know if I didn't pick the right coupler size or anything. Any idea of a ETA?
mtnbiker94
07-20-2011, 10:33 PM
Just got mine in the mail today! Installed everything easily, had to swap over the stock drive dog onto it because the one that came on it was a little to short for the stock prop, haven't gotten to run it with it on yet but I'll let you guys know when i do
dag-nabit
07-21-2011, 08:52 AM
Looking forward to hear your opinion on how they work. Mine shipped a couple days ago, but i will probably be a week or two waiting on international shipping, so any input will be appreciated.
Kevin
Jeff Wohlt
07-21-2011, 10:30 AM
What do you mean the drive dog being too short? The stock on is 4mm, correct? I even turn the 3/16 part of the shaft just a little longer. Please let me know as I want to make sure the 3/16x5/16 dogs work
Rcforever27
07-21-2011, 09:04 PM
Hey Jeff, what coupler do i need for your .078 wire drive?thanks.... Scott--
Jeff Wohlt
07-22-2011, 12:05 AM
either an Octura 5x78 or a set screw type. most orders are liking the octura version...just easier.
dag-nabit
07-22-2011, 11:27 PM
Jeff seems to get inundated with questions on the .187 flex cables and .078 wire drives. These are new to me as well so I thought I'd post up a couple photos of the different cable/wire drives for a visual comparison for everyone.
These are my first exposure to wire drives, the wire is very stiff, much stiffer than I was expecting and they are not going to work if the stuffing tube has any amount of bend in it. As Jeff has stated, I think the Spartan is a good candidate for a wire drive, I was planning on trying this one in my Genesis cat, but I'm certain I'm out of luck because of the curve in the stuffing tube.
Maybe I'll try them in the SV27's, but they have a pretty sharp upturn in the stuffing tube at the motor end as well, so not sure they will be suitable.
The Drive Cables
http://i173.photobucket.com/albums/w71/daidavies/RC%20Boats/ee250f05.jpg
Same order as above photo: Close up Showing Thickness and Flex Cable Wind.
http://i173.photobucket.com/albums/w71/daidavies/RC%20Boats/719b4cdc.jpg
Collets for Comparison: Different manufactures could be slightly different dimensions. The wire drives can also use a coupler with set screws for both the motor and shaft.
http://i173.photobucket.com/albums/w71/daidavies/RC%20Boats/2df86b44.jpg
Kevin
mtnbiker94
07-25-2011, 01:26 AM
I ran mine the other day, in a fairly small pound, however I forgot to bring my series connector so i could only run 3s, which wasn't too bad.
These wire drives are awesome to say the least! It ran extremely smooth with no heat or problems
All you need is the Spartan Wire Drive, The octura collet coupler(5mmx78) and I'm not sure if you need it but it looks really cool the Prop Nut 10/32 Thread $3.25
I'll let you guys know how it runs on 6s when i get the chance to run it again! Hopefully soon
Jeff Wohlt
07-25-2011, 04:18 PM
The wire drive will work much better than a big a$$ cable. Smoother, less friction and heat and no wind up. As long as they hold together with that big stub it should be fine. You can use the stock liner but I would like to find a liner that fits with a 125 ID in it.
Jeff Wohlt
07-25-2011, 04:20 PM
Dag-nabit...I may have to put you on the payroll as my marketing guy...LOL
mtnbiker94
07-26-2011, 10:55 AM
Ran mine today on 6s and it ran awesome, very little chine walk and no overheating in the drive line. However....I did toast my motor, about 3/4 through the run it started cutting out. Luckily it barely had enough juice to get it back to shore, but this of course wasn't because of the wire drive system!
Jeff Wohlt
07-26-2011, 12:31 PM
Glad to hear. Sorry to hear about the motor...now you can step it up :) Throw a 4082 in it on 6S
mtnbiker94
07-27-2011, 12:57 AM
Yeah I love it! And I've already called traxxas about it and got an RMA, now i just gotta wait...then once that gets to slow I'll eventually upgrade
Rcforever27
07-27-2011, 12:08 PM
Just got my wire drives and couplers from Jeff today.... Can't wait until the rest of my parts come off backorder.... Bare hull, brass tubing and liners....... Can't do much driveline stuff without the hull.... Anyways they look good Jeff! Keep up good work ! One question, you still have to grease these wire drives correct? Thanks again! Fast service and shipping also !
Jeff Wohlt
07-27-2011, 01:57 PM
Heck yes you need to lube it. I like any waterproof synthetic wheel bearing grease (walmart- Penzoil) and then I drip a little oil on it as well. I do the same with the stub end.
Rcforever27
07-27-2011, 02:45 PM
Lol ok i have grim racer grease and Prather cable grease..... Will do.... Thanks again!
bdp1174
07-27-2011, 04:10 PM
Hey Jeff I made an order on Saturday for a spartan wire drive, a .078 collet a .150 collet a drivedog and a prop nut.Did I get all the right stuff and any idea when they might ship?
(Brandon Peterson is the name on order)
Thanks again,
I look forward to trying this wire drive out.
Jeff Wohlt
07-27-2011, 04:45 PM
I am trying to catch up. I got some 5mm SS shaft that is not straight so wiating on some more. It should go out in the next day or so.
