View Full Version : Help finding motors similar to t600 880kv -maybe Himodel Pro series outrunners?
FastVee
07-07-2011, 03:44 PM
Any 1 tried 1?
I need something like 880kv t600´s ,but hc is out of stock.
These look good but I have no idea of comparing these ...
54999
http://www.himodel.com/electric/HiModel_PRO_Series_910KV_Outrunner_Brushless_Motor _for_600-700_Helicopter_Type_HG3740PRO-4T.html
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=11143
These are smaller dia then turnigy but longer.
Also no idea if these himodels use 25 or 30mm bolt pattern.
Would like to get my boat wet soon, but cant afford neus or leos atm.
siberianhusky
07-07-2011, 04:26 PM
the T-600's are Suppo outrunners I think re badged as HK or Turnigy. A search for suppo may find you a retailer of that same motor different label.
FastVee
07-07-2011, 04:40 PM
Thanks, could not find anything that looks like t600´s ,but on http://www.suppomodel.com/ ,they have same motors that I linked on himodel.
Really tempted to try these longer motors... -maybe even lower kv to get the smoking in control inside the boat...
siberianhusky
07-07-2011, 05:29 PM
Sorry my mistake that turnigy is not a suppo
http://www.hobbyking.com/hobbyking/store/%5F%5F11188%5F%5FTurnigy%5F600%5FH37404%5FBrushles s%5FOutrunner%5F910kv.html
is a suppo, same as the hi model one you linked to, I have the silver and black 3637 2t.
FastVee
07-07-2011, 06:05 PM
Thanks!
Still I have no idea what these are like compared to t600´s...
a bit smaller dia, but longer and 3000watts is not that bad (if that is true wattage).
ideas?
Pate
carlcisneros
07-07-2011, 09:51 PM
the Suppo 3740 and 3736 motors are a very good motor.
Make sure that you lock tight the set screw up in the end bell assembly as they sometimes do not use it.
As for the T-600's, I have no idea who actually makes those (and those are also very good motors.) (there price from HK is now 60 bucks and I paid 39 for mine last winter).
Fightercat57 on the forum here carries the suppo line of outrunners in a good KV range. (thats where I get mine).
FastVee
07-08-2011, 04:42 AM
Thanks, I ordered the 3740 910kv motors. Will reply when I have tested them.
I allways check the set screws, but thanks for the information.
I have 2 of the t600´s and paid 32$ . the price drops when you log in to hc.(I am platinum member so that could drop the price some also?)
Pate
