View Full Version : Turnigy 120A esc in stiletto?
jamespl
07-03-2011, 06:43 AM
My stiletto will be here tomorrow and I'm going to put a turnigy 120A esc in it rather than using the 60A proboat one. I have the program card for it but what timing should I use? Also I will be using 4s to start with but would I be ok running it on 5s in the future with the stock motor? Thanks.
Camaroracer
07-03-2011, 09:36 AM
as long as the esc is rated for 22.2v then it will be fine its a 1800kv motor so that about 40k rpm unloaded
jamespl
07-03-2011, 09:47 AM
I wasn't thinking 6s 22.2v just 5s 18.5v but the esc is rated 2-6s.
07-03-2011, 10:38 AM
Set the timing to 10-11 degrees. If you want to run 5S, put on a smaller prop to start with - amp draw will go up a bunch if you don't. I hope the Turnigy has a soft start feature, if so USE IT. This boat will flip onto its back with too much throttle off the beach.
jamespl
07-03-2011, 10:42 AM
I've seen that on some YouTube vids where it nearly takes off! I don't think it has a soft start but they have quite a good throttle range so you can start slow.
