RivRat34
06-30-2011, 01:47 AM
I need some help and ideas , I did noticed that the stock battery location does make it steering bad, because of it being the heaviest part of most electronics inside. So, should I move the motor/mount back somehow, and shorten the shaft/housing for props? If so, whats best way having them sticking in? EXPOY? Fiberglass resien? should I strip everything out and lay in some more fiberglass or carbon fiber? after reading most of the mods others have done... not quiet understanding what they did, math wise on making Center Of Gravity without messing with the weight distrubiton like someone left stock motor mounts location and put batteries forward inside hulls. that seems to be putting more weight up front and having to raise the prop degrees to lift front up??? or does he drive with front pushing water a lot loss of speed?
