View Full Version : New Member New Project With A British Twist
British Bulldog
06-27-2011, 09:13 AM
Afternoon all!
I'm a new member to the forum and as the title hints British, my girlfriend recently purchased me a new FE hull for my birthday from offshore electrics, so while I wait for that to arrive, I though I would take a few moments of your time to say a bit about myself and my intentions.
My Gf purchased the deltaforce 26" deep v mono hull for me (as directed) a hull i have found to be very capable of top speed and handling with very few stability problems, i'm sure many of you may know by now the Chinese produced knock off version of the hull, renamed the HOR rocket, or prince which its most commonly called. I have seen this hull in action and to be fair its a great little hull for a direct rip off, I have also seen the delta force go head to head with pretty much the same setup and honestly it pwns it outright, I just had to get my hands on one and turing 30 i needed a change of pace from the normal antics i get up to.
I'm not sure of the rules you guys use when racing hulls of this size, but here where i am there are a few rules to the boats in one particular class i will be entering this boat into, i will explain slightly later once the hull arrives and i can share my build with you, this will better explain why i'm using certain parts which may or may not seam a bit odd.
Well once the hull arrives ( I expect around 10 days or so) i will crack on and give you guys a bit of entertainment. thanks for listening.
Best Regards Bulldog
sundog
06-27-2011, 09:30 AM
Welcome. Looking forward to seeing the build.
British Bulldog
06-27-2011, 09:47 AM
Thanks for the warm welcome sundog.
As a bit of heads up i'm planning to run with most likely a strut and short rudder to keep the rear compact, but subject to change as always with any build, running off a inrunner 2680,4050 BL on 3's, i expect 32 or 35mm 1.2 pitch prop maybe 1.4 but yet this may change when doing trials, my aim is to beat that magic 55mph mark i expect that i can get 40-45 quite easily with a bit of light tuning, but i have a feeling i may have to push up to a larger motor to achieve this, but that will be subject to weight and tuning of the part's.
Any heads up advice is welcome, even perhaps if someone could give me some stats of the hull, is is GRP or polyester resin formed? (this will tell me if i need to add extra CF to the inside to help strengthen the hull) is the transom reinforced with a ply insert or will i have to fit one myself, or is is it recommended to increase the transom strength?
All these little bits will help me decide what to do and make my best laid plans feasible.
Best regards Bulldog
NativePaul
06-27-2011, 10:54 AM
Welcome.
I guess your setting it up for Mono1 with a smaller than usually seen 28mm motor on <280g 2s1p or 3s1p?
I'm interested in seeing this build as nearly all Monos round here are stepped hulls, the only hulls I've seen competing that aren't are the Hydro and Marine No-Step series.
Where in Britain are you? I'm in West Sussex and race with Electra and Ostend Ospreys, but also try to visit the other regions once a year and the Nats too.
http://www.electrafying.com
http://www.ostendospreys.com
British Bulldog
06-27-2011, 11:09 AM
Yes bud mono 1 indeed, i'm based in south east Devon, i have seen a lot of stepped hulls in the class run locally but have always found they are very 'skittish' when they hit some wake from other boats, on calm water man they fly but hitting rough they have to ease that throttle a bit.
I'm going with a 28mm motor as these little lepoard baby's do a great job with a small light weight hull running on 3's. also at £50 a motor paying any more becomes undesirable with my budget. If you have any recommended motors that would do a better job please by all mean post away, i would be interested to see what power plant & esc you would be running with. As i said nothing laid in stone everything can be changed.
best regards Bulldog
NativePaul
06-27-2011, 12:06 PM
I just changed from a 2s setup to a 3s setup in my Mono1 a twin stepped tenshock hull, I agree with steps being less stable and find hulls with 2 smaller steps to be better than single steps in that respect, I went with a 3400kv leopard 2860, on 3s ETTI 4500mAh with a de-tongued X435, but cant recommend it at the moment, it was pig slow, dont know if it was the motor ESC or LiPo but it definately had a problem somewhere, it was a good 10mph slower than my 2s setup of 4100kv HET 1w30 on 2s ETTI 5800mAh with the same prop, I was getting lapped every 3 laps by the fastest boat and I had only 12% left in the pack after the runs so not much room for propping up.
A 55mph Mono1 is very optimistic by the way, my Hydro2 was around that speed in oval trim at the last records day and I think the current world champion Mono2 was around 50 in oval trim, I would expect around 45 from a good Mono1.
Basstronics
06-27-2011, 12:37 PM
I got the "Prince". Have you visited the thread on RC Universe? Its chuck full of info.
I started out with the boat and still have it. Looking to Upgrade to a Pursuit soon.
My last runs were with a 3656 3000Kv @ 3s 4400 40C batts and K42 prop for 38 MPH @ 180 Amps. Ive tried a few props, a 42 x 1.4p seemed to work well but the plastic props wont stand up to the motor. Ive tried an X437/3 and it didnt work well for speed...
My next attempt will be hopefully this weekend with a Leopard 4074 2000KV @ 4S 5000 mah w/X440/3 prop.
I used to run a 2868 almost 3000Kv motor. It worked but a little small. Your prop selections seem very small. Its been noted with these hulls the X437/3 into the 42 prop area works well. Theres been a lot of testing, tuning and wasted money in the RCU thread. I suggest reading it and building a boat upon that testing.
Heres some pics:
http://i38.photobucket.com/albums/e136/basstronics/RC%20Boats/PICT0018.jpg
http://i38.photobucket.com/albums/e136/basstronics/RC%20Boats/PICT0002.jpg
http://i38.photobucket.com/albums/e136/basstronics/RC%20Boats/107_6719.jpg
http://i38.photobucket.com/albums/e136/basstronics/RC%20Boats/100_7317.jpg
Basstronics
06-27-2011, 12:41 PM
http://www.rcuniverse.com/forum/m_7713767/tm.htm
British Bulldog
06-27-2011, 01:45 PM
Thanks for the info Basstronics i will look a bit closer into the motors, at the moment is all speculation as to what i'm going to do, you know when you get a set idea in your head, then change it.. lol here we go !
Regards Bulldog
Boaterguy
06-27-2011, 03:24 PM
a 4050kv motor on 3S? that's alot of RPM.
British Bulldog
06-27-2011, 04:26 PM
That was what i was recommended for a mono 1 hull, maybe a larger prop is needed rather then my estimated 32-35, perhaps i should be looking around the 40- 42 mark? This is my first FE build (not my first boat build) so all help and advice is very much appreciated, I've learnt a lot over the past few months searching about before i make that dive in.
I've stood at the side lines and watched these guy race these boats for months and you get that itch to have a go, well this is my attempt, putting the boat together is the easy part, its making sure all the parts i put in are all going to work well together.
Right now it seams the motor, props size and pitch are my only real issues, i'm still tossing up between the 3/16th strut or the 1/8 (3.2mm) strut, i'm heading more towards the 3/16 for the range of larger props between 35 to 55mm that are out there and if i have to go larger on the motor then that's been suggested then i think the 3/16 shaft is the way to play it.
Best Regard Bulldog
Boaterguy
06-27-2011, 04:37 PM
I'm not saying put a bigger prop on, a motor of that kv on a boat will be a 2S motor, on 3S go with this motor http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=5145
the 35mm prop will go good on this.
martin
06-27-2011, 04:42 PM
4050kv on 3s is way to high ( 45000 rpm unloaded ) escpecially for racing mono 1 where you also have to get the runtime in as well, 40-42mm prop is also to big. The DF 26" on a 28mm can motor on 3s will do around mid to high 30s mph. Martin.
British Bulldog
06-27-2011, 05:19 PM
Ok that's great advice, that hobby kind turnigy motor looks pretty cool it was even mentioned in the post i read up on over at rchobby, basstronics suggested, just out of curiosity if i ran the 4050 with 2's 5000mha pack rather then 3's would that be a more reasonable rpm output with a smaller prop? what speeds would i been looking at? mid 30's low 40's? i need to get in 6 mins +10 sec mill time so say 8 mins off the battery to be on the safe side
Boaterguy
06-27-2011, 05:47 PM
that's about right for the 2S, but you'll be drawing lots of amps, A 3S lower KV, even lower than 3600, maybe 3300 would be better, then you'll be drawing less amps.
Basstronics
06-27-2011, 05:56 PM
Can you run 4S?
I dont know squat about boating rules for classes, I run for fun.
Seems most people having good results are running 4S setups.
British Bulldog
06-27-2011, 05:59 PM
I'm quite happy to run 2s at 5000 if a 3300 or a 3600 will give me a reasonable competitive speed ( at least in the 30's ) and the endurance time on the lipo. this is quite a learning curve for me, brushed motors i have no issues with but bl that's a whole new ball game.
im sorry the batterys availble to me for the class are,7 max sub “C” (43mm x 23mm nom.) NiCad or Nickel Metal Hydride cells or Maximum 2S1P 5000mAh LiPo or Maximum 3S2P 4600mAh A123
NativePaul
06-27-2011, 06:21 PM
So about 1.8KW to push a 26"mono at 38mph, that sounds pretty inefficient, I'd be surprised if bulldog doesn't get at least that speed using < the third of that power he has available to him as a Mono1.
Living in Devon will you be racing with SWAMBC (http://www.swambc.webeden.co.uk/#/fast-electric/4515893321)? if so you will be limited to 2s and 5000mAh, I know several guys that have not changed their motors from 2s to 3s and are at over 4000kv but it pretty much precludes you from using Octura props, Graupner carbon or Tenshock CnC have a much lower loading and will still let you run a semi decent size 33-35mm which is plenty for the typical stepped mono1 but the DF26 may take a little more pushing with its flat bottom, assuming that is the case I would go for about 4000kv on 2s or 3200 on 3s which should let you use X435 or 37.5mm graupner/Tenshock.
Americans tend to run lower Kv than we do in Europe with bigger props, I've been told several times on forums that my setups are SAWs only and will burn stuff up when I'm getting 5-6 minutes runtime and low temperatures by running props appropriate to the KV, smaller than they are thinking of. I have posted threads about it, but none have come up with a good explanation of why we run higher KV when we have little power available to us and Americans with many times our power spin their props slower, I can see it for monos where we have steps to loosen things up but its the same for hydros too, best I can come up with is it being a cultural thing like their big torquey V8 mustangs and chevys that used to race our little four banger minis and lotus cortinas in '60s touring car racing.
British Bulldog
06-27-2011, 06:29 PM
ok so that makes sense to a degree, please bare with me while i wrap my head around the two different points that have been made.
Paul i will be running in the SWAMBC mono 1 class so yes basically 2s are my limit, had to mod my post its so late i miss read your post, you answered the question i asked many thanks.
British Bulldog
06-27-2011, 07:09 PM
ok so going off whats been said and comparing whats availible pretty much im back where i started with the lepoard 4050kv motor in a 380 case size you can view here.
http://www.astecmodels.co.uk/catalog/product_info.php?cPath=24_114_118&products_id=1260
still requires the 100amp esc.
I can run the 3/16 strut with the 4mm adapter allowing for the use of 4mm bore prop's and i can also use a Octura X435 with a 4mm bore (you can see here)
http://www.prestwich.ndirect.co.uk/octurapropellers.htm
or any matching graupner 37.5mm props of 2s lipos should give me everything i need to at least be competitive in the swambc class.
If this is right ,that was basically my original plan and i wasn't mislead from the original advice given if its not then i think i need to go and do a bit more research to better my understanding.
Regards bulldog. oh and get some sleep cos i will be back tomorrow :D lol
Basstronics
06-27-2011, 07:27 PM
Edit I looked and I was drawing 156A with the 3060 3000KV motor.
Realize that was a cheap 2 pole hobby king motor I paid like $50 for a few years back. Its not a nicer Tacon or Leopard motor. Those motors are also known to be amp hogs. I dont think its characteristic to be that high of amperage if I run a better motor.
Dont go with 1/8 prop shaft. Entirely to small.
With that being said I would suggest:
http://www.astecmodels.co.uk/catalog/product_info.php?cPath=24_114_116&products_id=1186
4S power...
14.8 x 2050 = 30340 rpm
Maybe a Swordfish 200A ESC or a T180. Might get away with a converted Hobbywing 150A also...
Ive been down the 380 sized motors road before in this hull. Have a look:
http://www.youtube.com/watch?v=6YY5m8BphFU
Heres the 156A run @ 37mph (eagle tree data)
http://www.youtube.com/watch?v=cR5GK9YaRLg
LarrysDrifter
06-27-2011, 07:31 PM
So, you're a wrestler? I was a fan of yours in the '80's. Jk.
British Bulldog
06-28-2011, 04:06 AM
lol HULK HOLGAN! rawwww!
ok i'm guessing that there is this argument over motors with different views on what's best which i doubt will ever be solved, Paul is recommending i stick with the original plan of a 4050, Bass you suggesting the larger can but a 3660 that's less amp hungry, so both good suggestions, Bass i have limited options to run of 2s5000mah or 3s 4600mah as the race limits dictate so 4s are out.
So using the 3660kv I'll be using 3s 4600mah, if i used the 4050kv i be using the 2s 5000mah, they would both be using the x435 prop , now to throw my own spanner in the works... it has been noted (from pauls links) that in 2008 many of the setup's used are using the 380 can sizes in the 4000 range of motors with the same prop or similar to what i have suggested to use, as Paul said many have never changed there motors for a few years. So i can only agree with Pauls comments that the European series tend to just run higher kv motors as they prove to be effective.
Just to show what was used a few years ago, and really nothing much has changed a 2008 race setups one member used a feigao 380XL6 with a 70amp esc and a x435 prop,running off 2300mha lipos (assuming that's a 3s, seams a bit small for a 5min race but if its 2s thats pretty good but it is a lower amp draw which could explain it.)
There are a few other examples of similar can sized motors being used so i am more inclined to stick with my original thought of the 4050, Bass don't get me wrong your advice is very much welcome and your prince goes like a bat out of hell, i'm very impressed i just think for the UK mono 1 the 4050 may be best suited.
Best regards bulldog
Basstronics
06-28-2011, 06:15 AM
Eh limited by a rule. Thats cool. There are no rules when you just run for fun.. lol
NativePaul
06-28-2011, 02:06 PM
I think those 2300s weren't LiPos, but A123 LiFePo4s, there lower voltage than LiPo 3.3v nominal as opposed to 3.7v and you can run them in 3s2p for the 4600mAh you referred to earlier.
If your going 2s I would recommend a 120A ESC, you will be pulling half that on average but the current spikes can be 120A and I have seen plenty of 90A ESCs smoke in Mono1s.
British Bulldog
06-29-2011, 05:25 AM
Thanks Paul i think i may do just that 120 is only a few £ more then 100amp so not to worried about the extra if it saves the esc from burning up.
British Bulldog
06-30-2011, 08:53 AM
Well the hulls only about 200 miles from me so have enough time to order any outstanding parts, the one question i need to ask is about reinforcement of the hull.
I'm not sure if the hull is an epoxy layup or a polyester layup, i'm hoping it is epoxy which would make life easier, does anyone know exactly what layup the deltaforce delta hull is?
I'm thinking of going with a CF (carbon fiber) reinforced layer on the inside. Any suggestions on what is the best way to go about it?
I've layed up GRP many times in the past 20 years or so, so i know the dribs and drabs when using glass cloths & tissues, but CF is a whole new material I've never worked with.
If the hull is a polyester layup then reinforcement is defiantly needed, if its epoxy its doubtful i will have a need to do so being that epoxy is much stronger. I'm under the impression its a epoxy layup as polyester does tend to shrink during the curing phase (up to 7% in some cases) i can't imagine that hulll's of these types would be built that way?
but to be on the safe side, anyone know a good supplier of CF in small quantity's to do the inside of the hull? i'm thinking of using the west systems epoxy as its binder, but if you have an alternate suggestion i'm open to advice since CF may need a different resin.
Regards Bulldog
