View Full Version : Rx waterproof.. bag?
nosreme722
06-27-2011, 12:19 AM
where can i get one of those strechy rx waterproof things?
teach
06-27-2011, 01:17 AM
I used to use non lubed condoms....kind of hard to find though
sundog
06-27-2011, 09:44 AM
Just get some large size toy balloons at the local Dollar store and cut the necks off. Seal it with a nylon zip tie.
sailr
06-27-2011, 09:52 AM
Find a small zip lock bag. After inserting the receiver, twist the open end very tightly around the wires and use two small zip ties. Works great for me. Much easier than a balloon.
nosreme722
06-27-2011, 11:44 AM
Alright i'll try some of these, thanks.
ENCORE MAN
06-27-2011, 11:51 AM
Much superior to ballons as you can see any moisture in the bag. I prefer the freezer bags as they appear to be a little thicker. BG
Jeff Wohlt
06-27-2011, 11:56 AM
Go to hobby lobby and get some smaller jewelry bags...they work well.
sailr
hard to find any freezer bags that are small enough. Do you have a source?
ENCORE MAN
06-27-2011, 12:05 PM
No Jim, I just use the "small size" glad bags, cut them down, and twist them tight on the wires and double tie them as you do. BG
m4a1usr
06-27-2011, 12:46 PM
I just use the cut off finger sections from latex gloves. Get the extra large size and all but the pinky finger are just the perfect size. Then seal the end with a zip tie around the wires. Never had a drop enter my Rx since using this method.
John
nosreme722
06-27-2011, 03:20 PM
I used the figure of a plastic glove, see how that goes. Ill probably switch to a plastic bag soon b/c its a little bigger. Thanks guys
Boaterguy
06-27-2011, 03:29 PM
latex gloves, larger ones can fit your ESC too if you cut a finger for the wires on the other side, pretty much a flexible radio box.
Non lubed condoms, balloons, or really anything latex or rubber and stretchy. You don't have to cut the neck off, I have squeezed very large receivers through, although you may need two people to do it.
bigwaveohs
06-30-2011, 06:11 PM
or this...
