View Full Version : Twin ep1's
Outboardz
06-26-2011, 04:01 PM
I'm new to this, what radio, receiver, ESC's, batteries and such do I need to set up twin ep1 outboards? Any help would be appreatiated.
Thanks
Make-a-Wake
06-26-2011, 08:28 PM
If you are running brushed 550's a Traxxas EVX2 marine ESC should handle them. Those motors are only rated for 6-8 cells(nimh) so keep that in mind. You can also run 2s lipo.
Outboardz
06-26-2011, 08:48 PM
Thanks for the input. Will I need one esc for each motor? And on OSE, the nimh batteries are out of stock, what lipos should use?
Make-a-Wake
06-26-2011, 10:25 PM
You only need one ESC, it is wired for two motors. The EVX esc's come with a set of batt connectors for series connection. You only want 2s lipo..........you need to close the non-bec connector and use the other.
Good batt here since your motors will only draw around 15-20 amps:
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=16785
Outboardz
06-26-2011, 11:26 PM
Thanks again, and what radio/receiver should I use? I would prefer a non-pistol grip. Like the square kind (I don't know what they're called).
Make-a-Wake
06-26-2011, 11:38 PM
There may be some inexpensive ones on the hobbyking site........i bet there are.
Outboardz
06-26-2011, 11:46 PM
I found a few how many channels does it have to be? And will certain radios/receivers not work with the esc and stuff?
Make-a-Wake
06-27-2011, 12:14 AM
Get a 2.4ghz and you only need two channels. The only one i see that is 2 channel is a pistol, maybe you can get this and just use 2 of the 4 channels
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=8338
Outboardz
06-27-2011, 12:40 AM
Wow thanks I think that's every thing I need to get running. When I install them, I may a few more questions
Thanks.
Outboardz
06-27-2011, 01:15 AM
Oh, one more thing, what charger will work with those betteries?
Outboardz
06-28-2011, 02:39 AM
And if someone could please please tell me what steering servo and linkage rods andnsuch I need! Thats the last thing I need I think. If you could put a link to the right things that would be very much appreciated.
Thanks
