Basstronics
06-25-2011, 05:05 PM
With the bigger power Ive moved into with my 25" boat Im going to use 5.5mm bullets for power.
I bought the "Polymax" from HK because I already had an order I was building. These are junk. A fly could land on a wire and pull the two apart...
So I was at the LHS and seen some Castle ones. So I bought those. I just wired an ESC up and a charge lead. It takes a LOT to get these together. I gotta pull the wires to get them apart. I pulled so hard I ripped the heat shrink off my positive and mangled the negative.
I tried to crush the male one down a bit and I went to far.
Any advice? Or did I buy another $12 worth of junk connectors?
Kinda mad. Wanted to put the boat in the water this weekend!
