View Full Version : I have turnigy motor, But do not no it kv,Is there a way to find it out ?
lenny
06-23-2011, 02:44 PM
Hi,:thumbup:
How can i find the kv of a motor if unknown ?:glare:
Its orange colored and has 4 vents at each end, I think it a Turnigy motor 36MM/56mm/ / 5MM shaft. 2 pole.
It looks like one.
Thanks for any info.:beerchug:
:popcorn2:
kookie_guy
06-23-2011, 02:56 PM
is it one of these.....
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=6527
Darin Jordan
06-23-2011, 03:15 PM
If you have an Eagle Tree, you can hook it up, measure the max RPM and voltage, and do some division...
lenny
06-23-2011, 03:26 PM
I think so, It looks just like them, But no tag is on it, I got it off of swap shop on hear, But no info on it.
Trying to use it for a 2s setup for my Rio ep to go brushless soon with low amps for esc.
It feels like two pole to me when i spin it.
Boaterguy
06-23-2011, 03:29 PM
there is a way to do it with a poer drill, or another motor with a set RPM, I forget how, it might be on the tips/tricks section of this site.
lenny
06-23-2011, 03:38 PM
I saw in tips something about a using a drill with known rpm,
But unshore about how that works.
No i don't have a eagle tree yet.
Boaterguy
06-23-2011, 03:47 PM
you put the motor shaft in the drill and spin it at an rpm, use X. put a voltemeter on two of the wires, use the voltage you get as Y. then run them through this formula. (X/Y)/1.41
the answer you get will give you your motor KV
lenny
06-23-2011, 04:35 PM
Just tried it, But volts are not stable on the meter.
600 rpm drill, DM-55 Greenlee multimeter.
