View Full Version : A Turnigy Marine 120A can run a 3674 2800kv motor?
adrianofbr
06-21-2011, 06:47 PM
Hi guys,
I can run a kd36-74 2800kv motor with an Esc Turnigy Marine 120A? I'll run with 4s 4000mAh 40C in a boat with a 42x29x15 Turnigy Prop (plastic). I'm plan to change the prop for a X442 in the future. In the spec it say's that the motor will draw 110A, but i'm not sure if i'll cook my motor. Anyone have see this setup?
Esc Link (http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=8946)
Motor Link (http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=6677)
Thank you,
Adriano
Rumdog
06-21-2011, 06:54 PM
The motor can and will pull more amps than that. That is the listed max operating amperage of the motor.
It reall is a 3s motor for sport use.
martin
06-21-2011, 06:56 PM
That motor wont last long on 4s, The kv is to high at 2800kv. That will give you over 41,000rpm unloaded. Cheap motors & those sort of revs dont go well together.
What would this setup draw on 3S?
Greg
Alexgar
06-21-2011, 08:41 PM
110 amps is the rated current I had one more like 150
WOW
Is there a formula somewhere that we can use?
I'm still can't get my head around calcing amps to pick a speed control.
Greg
Alexgar
06-21-2011, 09:39 PM
Etti 150 or t180 or sf 200 I burnt a suppo 200 at 120 a so steer clear unless your ready to remounting the heatsink
Make-a-Wake
06-21-2011, 10:27 PM
Use a T180 and run it on 3s............
adrianofbr
06-22-2011, 09:18 PM
Thanks guys. Ill keep my stock motor now and wait a T180 to put this motor.
Boaterguy
06-22-2011, 09:33 PM
does ben not have the suppo 200 kit with cooling plate and caps?
Hmmm makes me wonder bout my new setup. Seeking 120 with tacon 3674 1900 kv on x442. Any thoughts?
Alexgar
06-22-2011, 10:42 PM
I havent seen those escs in his shop for a while
Make-a-Wake
06-22-2011, 11:15 PM
The 120 will handle that setup fine..........i ran a 4074 2200kv in my Pursuit with a 120 and an x442 and it held up.......went to a T180 for more room though.
Great news to me! I plan on running a 125 amp esc in my apparition with either a 4074 2150kv or 3674 1900kv tacon on 4s. I'm looking for 40 to 50 mph so ill be running a similar prop. What voltage were you running with this setup and what speeds were you getting with that x442? What temps were you getting?
Make-a-Wake
06-22-2011, 11:31 PM
My temps were always below 125* on the ESC...........just in the warm zone really. I hit 46 mph with this setup and it was very solid overall.
Using the speed calc I should get near 50 with the x440 prop with the 3674 1900kv on 4s. 1.4x40x1900x16.8/36970=48.3 mph. I think this would be my ideal sport setup.
carlcisneros
06-23-2011, 10:56 AM
Ben dropped the suppo line of ESC's a while back. too much of a headache.
