View Full Version : Hobbyking apparition props
I have a apparition on the way and was curious if anyone has experimented with different props. It is a 4mm shaft so the selection is not very large. Im not sure what the stock prop is, i think 38mm? Hobbyking had only a few 4mm props to choose from, 32mm, 34mm, and 42mm. I went ahead and ordered a couple 42mm props they were only a buck each so worth a try. In the future im going to look into getting the drive dog and sleeve to adapt 3/16 props, much more of a selection of those and dont have to wait 2 week to get them from china.
Alexgar
06-18-2011, 09:20 PM
You can use a piece of brass tubing as a shim to use 3/16 prop I use a m545 and a tfl 47 prop like the one sold here under misc props
I got some 3/16 tube on the way, and balancing a x442 right now. So that m545, your running that on an apparition? What motor/esc you running?
The x442 prop runs good on the apparition. I might try x640 in the future.
