View Full Version : t180 motor wire shortening
millzee
06-17-2011, 11:13 AM
I've been trying to figure out a way to fit the t180 into a tight fit in my mm build and whilst playing around with a few ideas, I found that the female EC5 connectors fit perfectly (after a clean up with a file) onto the wire attachment fitting that come on the t180. I unsoldered the wires, and soldered on the ec5's, now it fit's like a glove. I'm only putting this up here to hopefully help anyone who might be in the same position at some point and this might come in handy.
Before soldering
http://i1219.photobucket.com/albums/dd439/1millzee/MeanMachine034.jpg
After soldering
http://i1219.photobucket.com/albums/dd439/1millzee/MeanMachine039.jpg
Heat shrink
http://i1219.photobucket.com/albums/dd439/1millzee/MeanMachine042.jpg
Now fitted
http://i1219.photobucket.com/albums/dd439/1millzee/MeanMachine044.jpg
another fitted, I'm nearly ready to hook up some batteries, calibrate, program and bash this little beast
http://i1219.photobucket.com/albums/dd439/1millzee/MeanMachine059.jpg
I hope this will help someone down the track.
Danny
millzee
06-18-2011, 03:54 AM
I take it from the overwhelming responce, this has been done before?
carlcisneros
06-18-2011, 08:00 PM
first i have seen of it.
looks very nice and will probably use that tip on a new future project.
thanks very much.
Alexgar
06-18-2011, 09:22 PM
I've never had the need bit great idea
99z286spd
06-18-2011, 11:23 PM
I didnt need the wiring idea but i sure like how you have it plumbed!
Thanks for posting..
Shooter
06-19-2011, 10:19 AM
Great idea Millzee!
millzee
06-19-2011, 12:02 PM
Thanks guy's, I hope it'll come in handy for you
mtnbiker94
06-19-2011, 12:54 PM
Does the T180 come with 6 caps now? Or did you ad them on?
millzee
06-19-2011, 06:10 PM
I added three more
properchopper
06-20-2011, 12:26 PM
Take it to the next level by cleaning up the water inlets/outlets. Works great for squeezing into tunnels or riggers :thumbup1:
millzee
06-20-2011, 07:29 PM
I love it, so much more compact, I'll take a look at it tonight.:thumbup:
Shooter
06-20-2011, 09:25 PM
Now we're talkin'....... perfect fit! Almost as if it was made for a tunnel. Thanks Tony!
millzee
07-04-2011, 10:33 AM
After now setting the electronics up in my boat, I've spent hours trying to calibrate the esc and had no success, I'll now have to go through the calibration process each time I run the boat. A wise man informed me that by adding the bullets directly to the board, I may have damaged a memory chip.(Thanks Mate:thumbup1:)
I'll be happy for this thread to just disappear:laugh:, I don't want to look back in a few year and be reminded how stupid I was
properchopper
07-04-2011, 11:43 AM
:thumbdown::thumbdown:Don't try this mod at home:thumbsdown::thumbsdown:
Hmmm.... Seems that Steve L. did that mod to the T-180 in his spec FE 30 and had a complete meltdown of the speedy and motor at the last race although everything was seemingly installed with precision. You may be on to something here !
07-04-2011, 11:50 AM
I'd suggest going back to the first post in the thread and placing the big warning there too....just to make sure everyone sees it. Sorry you found out the hard way! :sad:
Tunda
07-04-2011, 01:31 PM
Thanks for taking one for the team..............:biggrin:
millzee
07-04-2011, 05:41 PM
I'm sorry if my ignorance and lack of knowledge has mislead anyone, I'll be sure to test things through better before starting any threads in the future.:sorry::Peace_Sign:
Shooter
07-04-2011, 06:09 PM
Make sure your esc still returns to neural when losing signal. After programming mode, all of my 180's default to full throttle when signal is lost. To test, simply turn your controller off at 1/4 throttle (out of the water). The only way you can avoid this is to turn your esc off and back on after programming.
millzee
08-23-2011, 01:59 AM
ALL GOOD, TURNS OUT IT WAS THE RX
After having a lot of trouble calirating a sf200 with the same rx, I've discovered that this esc is fine, it was the receiver the whole time:doh:
I've just calibrated the esc successfully with three different receivers and they all work properly 1st time. This is great news for me, I can feel like I finally had something I've tried go right for me:w00t::banana:
Make-a-Wake
08-23-2011, 09:55 PM
Great news there....................i was unsure about it messing up the programming.........didnt seem right.
BTW, what would we all do without T180's.........???? We'd be SOL for a $77 180a 6s ESC thats for sure...............great speedo's!
