View Full Version : Go home Turnigy!!!
Boaterguy
06-16-2011, 09:00 PM
so, my second t120 decided to blow on me today, I was running 3S and drawing way under 120A, it just died. brought it in and changed the caps since they looked puffed.
plugged it in and got nothing, so I plugged in a batt to the RX and the magic smoke came out. I can't complain, the turnigy smoke smells relatively good, or maybe u'm just getting used to it...:cursing::cursing:
v-spec
06-16-2011, 10:38 PM
Unlucky, only thing that burns on me are castles.
tiqueman
06-16-2011, 11:45 PM
I love my 120s. One of the most reliable ESCs I run. Running 4, 5 and 6S in several of them. And Id rather a $50 esc blow than a $200. Id say your still ahead of the game.
Boaterguy
06-17-2011, 06:42 AM
I'm going with an SS 190-200 now, since i'm gtting one for my rigger, theyll share it.
siberianhusky
06-17-2011, 07:46 AM
Never owned one but from what I've read about those HK SS esc's is that the 200 amps is the absolute maximum it should ever see, not much of a burst rating to them.
Is this the one you burnt out running your hydro in the pool? I remember that thread from a while ago.
tiqueman
06-17-2011, 08:54 AM
Oh my. Good luck w that. I had two, my neighbor had one and another friend had one. Note the use of "had". They are junk. None lasted more than 3 mo. With well under 100a on all of them. Shoulda stuck w the t120 or gone to the 180...
rc2266
06-17-2011, 09:46 AM
I submerged mine at least 4 times(maybe I should coat it), still running strong, but I think I will go with the t180's from now on, seems like a great esc
Boaterguy
06-17-2011, 02:58 PM
this is the one I bought to replace that one... ugh.
t180's are out of stock, who knows how long so, this is the next best thing, I'll get the air version since I have two t120 heat sinks now, hehe
http://www.offshoreelectrics.com/proddetail.php?prod=ker-seaking-180
Boaterguy
06-17-2011, 03:07 PM
yeah, i wish..
I can't afford much right now, that's why I'm getting an SS
a CC HV 240 would be great, that's what I would get if I was spending money. oh well
rc2266
06-17-2011, 03:37 PM
OSE shows 47 T180's in stock now
Boaterguy
06-17-2011, 04:02 PM
still can't afford it, 100$ for an ESC on an old boat that wasn't built right is too much. the boat won't get an ESC right now, it'll just share one with the rigger, the rigger will get an SS, maybe i'll get two, just in case.
tiqueman
06-18-2011, 03:12 PM
Boater, I got a deal for you. $20.00 I will send you a brand new in package SS200 I got from Fightercat racing. Its still in its packaging. It was the type in kit form that you have to install the heat sink and wrap it. It comes w/ everything you need.
Just opened packing so I could take a pic of all the components. PM me if your interested.
-Scott
Boaterguy
06-18-2011, 04:40 PM
In toronto for the weekend, i'll PM you later tonight or tomorrow.
rc2266
06-18-2011, 08:52 PM
If u tun that down ur insane
Boaterguy
06-18-2011, 09:25 PM
I'm not turning it down, I can't contact him at the moment so I will when I get home from toronto.
tiqueman
06-19-2011, 09:42 AM
No worries. It will be here whenever your ready
wparsons
06-25-2011, 07:04 PM
Couple questions... How do you know you were pulling under 120a? What boat, motor, prop, etc is this in? What pack were you running, were the capable of supplying enough current for the motor?
When you plugged in the RX battery, did you pull the red wire from the ESC plug so you weren't feeding power back into the BEC side of the ESC?
These ESC's come highly reviewed and seem to take a lot of abuse, I find it very strange that you've blown two in such a short time period.
Boaterguy
06-25-2011, 07:48 PM
This I did not do, but there was no spark. when the battery was plugged in
I was running a turnigy 3S 4000mah 40C battery on a 3600KV supervee prop.
the battery radio and motor I know all were functioning properly.
the ESC did not heat up too much, that wasn't the problem.
tiqueman
06-25-2011, 08:09 PM
Probably why your blowing escs. If run an rx pack, you have to dissable the bec by removing the red wire out of the plastic plug. Id say by feeding it two ways you blew them.
Boaterguy
06-25-2011, 08:25 PM
I wasn't running an RX pack, that was just to test if a specific part of the ESC was broken, it was the first time it was run that way.
wparsons
06-25-2011, 09:32 PM
You just said that it let out the magic smoke when you plugged in the RX pack... If you're running a receiver pack you have to pull the red wire out of the ESC plug to the receiver, it wouldn't spark if you left it in, but it would harm the ESC since you're feeding power the wrong way through the BEC circuit.
What happened before you plugged in the RX pack?
I'd say the 3600kv motor on 3s with a 40mm 3 blade prop is also a potential issue, that's a lot of RPM (45k unloaded) and a pretty big prop. If you pull enough current to blow it quickly it won't necessarily be warm or hot.
Boaterguy
06-25-2011, 09:52 PM
It worked fine before, I ran the BEC on 3S with no RX pack, and one day it decided to die in the middle of the lake, the caps were puffed, they got replaced with bigger ones (35v 1000uf). even after that, there was not a spark when the batts got plugged in. so that's when I tried to put in an RX pack just to see what was going on, as soon as the smoke came the battery and ESC were unplugged from the RX
wparsons
06-25-2011, 10:00 PM
Typically caps only die or puff if the packs aren't supply enough constant current, resulting in ripple currents and spikes. So either you were drawing more than 160a, or the batteries weren't happy supplying whatever the motor was drawing. I would bet you were pulling a lot more current than you thought with a 3600kv motor on 3s with the 40mm 3 blade prop.
Even if the ESC is dead, if the caps are soldered correctly it will still spark. The spark is from the caps charging up, not the ESC taking power.
Boaterguy
06-25-2011, 10:12 PM
okay, well it didn't even with the new caps, they were soldered directly onto the battery wires and not the ports since I could not solder in that small area safely
wparsons
06-25-2011, 11:08 PM
How were they soldered, correct polarity, in parallel or series?
Boaterguy
06-25-2011, 11:09 PM
Parallel, proper polarity.
TheShaughnessy
06-27-2011, 04:59 PM
i agree with that. less voltage to achieve more rpm is always gonna make the amps go up. I have 2 120s that see 100 amp peaks regularly and never come in warmer then 140 ish, generally much cooler then that. I think you might blame the motor and prop before the esc. Have you tried adding caps before the esc goes? I have added 2 extra to each of mine, no problems to date.
Boaterguy
06-27-2011, 05:03 PM
It's okay, I'm done with turnigy, I'll try the SS series for a bit, but the hydro will share an ESC with my rigger for now.
wparsons
06-27-2011, 05:07 PM
IMO, stay away from the SS series... They're a low budget lower quality ESC than the Turnigy line. If you're popping T120's, you'll blow the SS125a way faster.
Boaterguy
06-27-2011, 05:09 PM
I'll get the 200A and hopefully I don't blow it .
Not in the mood for working on that boat right now, it needs alot.
markus
07-30-2011, 10:59 AM
I also had an 120 cook on me , went with a cc 200 hv very happy.
wparsons
07-30-2011, 11:43 AM
What boat were you running it in that you went from a 120a ESC to a 200a HV? That's a really drastic difference.
3600Kv * 11.1v = 39960 RPMs
Pwb201
10-22-2011, 11:48 PM
Turnigys suxs. Agreed.
tiqueman
10-22-2011, 11:56 PM
9 to date in 2 yrs and 2 have failed. I love them. One, no idea what happen.. just started doin a studder thing.. resoldered everything still did it. The other, totally my fault. 6s on a 180, factory bec.. popped it and next run the esc itself died. Can't blame escs for user error.
ray schrauwen
10-23-2011, 08:34 PM
The $20 esc deal is a good deal but, in general you are going backwards from Turnigy to SS esc's.
Fightercat Racing has an excellent esc for $54, 140 amp, small and tough as nails!!!
Boaterguy
10-23-2011, 09:00 PM
it's on the way
the setup in this boat has been changed to the FC 2000kv outrunner on 5S. i'm gonna start with a 40 mm prop because I was using SS 200's and they weren't stone cold, i was running a 42.
ray schrauwen
10-23-2011, 09:07 PM
Well, then, thats a different story since the SS or Suppo esc you have coming was designed to run with outrunners.
Just make sure you set the timing to at least 22 degrees to 30 degrees to keep it cool.
If you fo to an inrunner, other esc's are a little better designed..
Ive had 2 swordfish 200amp esc' without bec on 6s pushing x447 twins and i have blown two in less than 5 seconds.. no shaft friction, no water, no bec.... I'm thinking they are crap!!
Boaterguy
10-24-2011, 07:00 AM
i blew three of them in a week
i asked Ben and he said 8Khz 15 degrees.
maybe i'll do 23 degrees just because i can
