View Full Version : Max motor KV for 3s set-up?
Andris Golts
06-16-2011, 12:02 AM
Hi all decided to set-up my 16''' micro hydro on 3s 11.1v lipo . What is the max kv rating i should consider for the brushless motor? Regards Andris Golts.
Alexgar
06-16-2011, 12:40 AM
3200-3500
HyperJack
06-16-2011, 03:04 AM
I am using the motor with 4800kV on 3S. The propeler is Graupner K30.
SweetAccord
06-16-2011, 12:38 PM
3500-4200 should be the sweet spots. The higher KV you go obviously shorter run times and more heat, and may gain 1-5 RPM but more wear and tear and pull higher amps. You would also will have to use smaller props. It's better to KV down a little and run a larger prop which will give you a nice balance overall, but obviously its up to you.
Andris Golts
06-20-2011, 04:10 PM
Thanks to all for the great info. Regards Andris Golts.
