View Full Version : blackjack brushlesss shaft and prop
02-12-2008, 10:46 AM
Does anyone have a picture or info on the shaft sizes of the bj26 bl?
Also what prop comes stock? Does it come with a sleeve to fit the larger props.
I would look at one, but I ran out of them and need to find out asap.
Look up Doby Steven. I believe I sold him a complete setup not to long ago. I will look for my pics also.
domwilson
02-12-2008, 12:06 PM
I think it is a 1/8" shaft.
Prop Size:1.6" X 2.5" COMPOSITE
and it uses a sleeve to fit 3/16" props.
02-12-2008, 12:19 PM
Dom I'm trying to figure if the blackjack brushless comes with the sleeve and uses a 3/16" stock prop?
obrien
02-12-2008, 12:31 PM
my boat did not come with a sleeve. I had to make one.
domwilson
02-12-2008, 01:05 PM
Mine came with a brass sleeve and it is the 3/16" stock prop.
Apples1
02-12-2008, 11:02 PM
mine came with no sleeve, so if i get this it should be ok? i want to run the 642 http://www.offshoreelectrics.com/proddetail.php?prod=ose-1035
not sure about prop shaft sizes, it's not a 3/16 stock shaft as i have these in my EX (an upgrade) to run X447 props and these wont fit on my BJ26 BL
Octura x447
Diameter: 1.85"
Total Pitch: 1.4x1.85=2.590"
Shaft Size: 3/16"
Will double check tonight.
domwilson
02-13-2008, 12:53 AM
I double checked. It is a 1/8" shaft. The prop is a 3/16" prop with a brass sleeve. Same prop as the TC31
http://www.horizonhobby.com/Products/RelatedPartsSummary.aspx?ProdID=PRB0151
02-13-2008, 07:27 AM
Octura x447
Diameter: 1.85"
Shaft Size: 3/16"
Apples and Obrien can you guys check to see if the sleeve is stuck inside the stock prop. If it didn't have a sleeve the stock prop would be really loose on the shaft. Is this the case?
RCprince
02-13-2008, 02:32 PM
Steve the stock prop came with a brass sleeve, the drive dog was on a 1/8 shaft with sleeves on the back and front of the steerable out drive...
Apples1
02-13-2008, 02:41 PM
sorry guys didnt get a chance to check last night, but the prop certainly isnt loose on the shaft.
cheers guys.
gaboulware
02-13-2008, 11:23 PM
There is a brass sleeve wedged into the stock prop reducing from 3/16" to 1/8"
02-14-2008, 10:18 AM
thanks for all the help
Apples1
02-14-2008, 09:51 PM
that is true....however an aftermarket prop wont fit on the stock set up, the length of the shaft isnt long enough (or the prop os to big) and the little piece of steel that stops the prop from spinning is to small for my x447
