View Full Version : Spektrum MR3000 question
kookie_guy
06-04-2011, 11:02 AM
When hooking up 2 ESC's to the receiver (as you all know it has 2 throttle connections) do I need to pull one of the red ESC wires to disable the BEC? Or has that already been done internally in the receiver?
battlefury
06-04-2011, 11:11 AM
it is advisable to pull out both red wires from both esc and supply with external RX bat. pack
the rx only sync to its indivdual TH channel. Leaving one red wire and unplugging the other red wire meant only one esc is active with BEC not two. hopes this helps
