View Full Version : Do I Cut Them?
LiPo Power
06-03-2011, 06:00 PM
I am upgrading Stiletto with Hyperformance Flex shaft and 3.5 Bullet Shaft Assembly:
http://www.offshoreelectrics.com/proddetail.php?prod=hpi-psa35
http://www.offshoreelectrics.com/proddetail.php?prod=hpi-dc1563s2
Looks like the flex is a little longer than stock.
Do I need to cut the flex or is it going to work fine the way it is?
Thanks
Robert
CHIEFY_44
06-04-2011, 12:50 AM
i did the same upgrade on my stiletto, you may need to chop a very little bit off the shaft, i am lucky hyperpeformance is only 20 mins down the road so i went to see them and he has a flex shaft there that fits without chopping it if u ring them and ask for the flex shaft with the dark spiral line on it it fits a treat. have you done the brass tube instead of the teflon?? if not i reconmend you do, if u look back at darin's set up bit in here he tells you how to do it and it really does make the difference.
CHIEFY_44
06-04-2011, 12:51 AM
you could also make the flat on the motor shaft longer and move the collet
LiPo Power
06-05-2011, 10:57 AM
Tank You, good staff....
Robert
