View Full Version : Mini Rio Newbie Qns
doggie
05-27-2011, 11:26 PM
Just got my hands on my mini Rio yest. Upgraded to brusless with this set up:
Hobbywing Seaking 35A
Align 400 size 2700kv b/l
stock prop
3s 1300mah Lipo with deans
Boat still had the issue of getting on plane .. moreover it kept self turning to one side irregardless of trim . kept havin to counter steer to keep straight , is it coz of the batts n weight balance of the boat? ... it's only after a few correct turns or keeping it straight for abit than it boat catches on plane an starts zooming away at an amazing speed .. is this normal for boats ?
sorry guys it's my 1st foray into RC boats .. soo I'm just v v lost .. feels my boat is too heavy at the back . mounted the RX there ... esc weight is rear bias too .. should I move it more to the front hatch?
Any advice on changing the props soo that it's easier to get on plane immediately ?
regards and thanks guys
larryrose11
05-28-2011, 07:19 AM
The mini Rio likes front balance balance, around the center of the front access hole.
Might also be the prop. Im not sure what the stock setup was, but broke mine.
I ended up gutting the hull, installing a new drive setup and hadrware. I use a plastic y531 prop (http://www.offshoreelectrics.com/proddetail.php?prod=oct-y531).
http://forums.offshoreelectrics.com/album.php?albumid=403
I ended up dticing the spacer on the strut (http://www.offshoreelectrics.com/proddetail.php?prod=ose-80046). It was porposing.
tiqueman
05-28-2011, 11:00 AM
When I had mine bfore the abyss took it, I mounted my motor just about where the original was, battery was under the part of the deck between the two access holes, a little more towards the rear, esc was mounted on the foam in the bow. RX was to the starbord side of the motor mount... I think. It took off very well and was crazy to run.
I also ran the strut Larry showed and the mini rudder as well.
Biggest thing I can say is add flotation. It will sink if you blow a hatch seal which is what I did. 6 feet of water and its been down since April of '10. I gave up looking for it as I think the lockness ate it.
doggie
05-28-2011, 11:50 AM
hey thanks !! I now mount my eSc the same way u did ... getting more weight to the front ... it now gets on plane almost immed.. it's still steering towards left thou . I'm trying to compensate using my controller settings thou . speeds great .. but I flipped ovr twice tonite ..(now i lower my EPA and EXp) had to dive into my pool to retrieve it.. can't wait to test some ore b4 bringing it to the pond ...
doggie
05-28-2011, 11:55 AM
Oh my sorry to head abt yr lost ... I'm still running my in my pool thou at abt 70% settings ... stock prop... how do u add flotation? add more foam into the boat ?
tiqueman
05-28-2011, 01:38 PM
Yeah just add some cut up pool noodles or something.
I used to have this as my signature...
Final moments of the Brushless mini rio in emoticons. :w00t: :ohmy: :eek::Sinking: :cursing: :crying:
doggie
05-28-2011, 10:33 PM
boats been running great .. snapped my stock drive cable on my 4th run... *went swimming yet again*
larryrose11
01-24-2012, 10:24 AM
Doggie,
That happened to me. I took out the stock stuffing tube, and upgraded to the 0.98 flex. Didn't happen any more.
I smashed it bad last season, SO, Im gutting the Mini Rio right now for am major overhaul. Lots of new fibrerglass. Re-doing the top deck and hatch to I can tape it well. New layout with a ADS400XL motor near the back, bigger batteries at the front, since they are the heaviest part. Pics to come.
