View Full Version : Stripping motor coupler
MfizzleS62
05-24-2011, 11:07 PM
Any one having issues with these??? So far my second coupler one of the set screws stripped out .... Not the screw the actual coupler... This is the second one... Anyone else have this issue??? It's getting impossible to maintain the flex shaft greasing it after every run when the coupler is so weak and soft... I need a real upgrade on this part !!
VenomP1
05-25-2011, 06:48 PM
To regrease the flex shaft after every run is a bit excessive i regrease mine after about 4 or 5 runs and as long as you do this regularly things should be fine.:unsure:
MfizzleS62
05-25-2011, 07:35 PM
Thanks for the response... Even if I do it every 5 runs it still runs the risk of stripping the part while tightening the set screws... Its tough to tighten the screws so the flex shaft doesn't move without stripping the coupler...
GRIF
05-25-2011, 07:53 PM
WOW sorry to hear about your P1, when you get your new parts use some( LOW strangth loctite) and dont crank it down so much. Its been working for me for years
GRIF
MfizzleS62
05-25-2011, 08:45 PM
I just ordered 5 couplers !! These better last me the season!!!
