View Full Version : Charging multiple Lipos
nosreme722
05-22-2011, 12:40 AM
I was looking at the ose tips/info about charging multiple lipos at the same time..
http://www.offshoreelectrics.com/info-pages/charging-multiple-packs.php
Im new here and was wondering if i could just do the same setup as this:
http://www.offshoreelectrics.com/info-pages/images/yharness.JPG
but with 5.5 bullets connectors.. the same series setup as in the boat
I have a sky B6AC charger (it says dual charger?)
http://www.hobbypartz.com/skychb6chdup.html
And I was planning on charging two 2s 5200mah packs. Wondering if this was possible and if so any tips and such. Thanks!
:bounce:
nosreme722
05-22-2011, 08:51 PM
hello?
05-23-2011, 06:15 AM
I only charge lipo using the balance taps. It's the safest way to charge.
Shaun78
05-23-2011, 06:25 AM
EPBuddy.com sells paraboards. They will allow you to charge same cell lipos MAH rating doesnt matter at the same time. JUST MAKE SURE PACKS ARE AT THE SAME STATE OF CHARGE. WITHIN .1 to .4 VOLTS but the closer the better. Also you will need a charger capable to do this
Philmunsterman
05-23-2011, 12:44 PM
For that charger it looks like when they say " dual " it means AC or DC power. I'm not sure it would save you any time charging one vs. both Lipos at once. Phil
sailr
05-23-2011, 01:04 PM
With a Y adapter (series) you can charge two 2S batts together as one 4S. You could do the same with 3S and charge as 6S but that would be the limit of that charger. One drawback is that you cannot balance charge both packs this way but you can charge the packs separate every 2 or 3 cycles to keep them balanced. It normally is not necessary to balance the packs every single time but you do need to have a meter to check the individual cells in the pack. If one or more cells is more than .3 or .4V difference than the others, you need to balance charge. Balance charging with that charger takes forever! I have two of them. They are truly a great charger actually.
nosreme722
05-23-2011, 05:21 PM
So how long would if take to charge a 2s 5200mah battery by itself?
maxmekker
05-24-2011, 02:42 AM
Here is how I do it.
http://www.youtube.com/watch?v=t8L_c-cFpSQ
When I had the first dual(12v/230v) bantam charger , and started with 6s for my trex it became to small, only 50watt. so I got he bc6-10 .
Now I have the 3010 I charger and on that 2x 2s 4000mha takes about 25 min FAST charge
and in balance mode i would guess in the 35'ish.
