View Full Version : ETTI esc's
freakyfoti
05-21-2011, 11:50 AM
Any word yet if ETTI will or has made a USB / PC programing connection yet ?
I got one from this website ( OSE ) and i haven't even used it yet because i can't seem to program it right with a transmitter. :doh:
:beerchug:
martin
05-21-2011, 12:56 PM
I use Etti esc as well as others, As far as i know you still have to programe through the tx. Which is fairly straight foward if your used to doing it. Do you have the programe instrutions for the Etti. Martin.
m4a1usr
05-21-2011, 01:16 PM
It would be nice to have ETTI make that upgrade soon. I havent heard of them producing any USB versions yet. Still, all in all, the ETTI is a very decent speedo. It takes a bit of practice to get one programmed with a Tx but its not horrible. You just have to get to understand the tones and listen to the order in which they sound. I have noticed that the tone and loudness seems the clearest with 2 pole motors. Dont know why that is but I sure seem to hear the programming tones the best with a cheap hxt 36-50 connected. Once I get the speedo set on the bench I then move it into the hull its meant for. Just use the radio system that the boat will run with. But for a programming aid you can use any motor that will work. http://www.himodel.com/en/rc_manuals_url.php?id=164
You can watch the programming video on Jeff Wholts web site too. http://www.rcraceboat.com/rcraceboatesc.html
John
