Neu "D" wind motors
  • LarrysDrifter
    Big Booty Daddy
    • May 2010
    • 3278
    Neu "D" wind motors
    I know Delta wind motors are known for running higher temps than Wye winds. My friend has two D wind motors in a twin cat with no heat issues. I'm interested in a Neu 1527 motor for a single drive application in a mid 30" inch mono on 6s. I've heard good things about the 1Y using a big prop. My other option is a 1.5D if I remember correctly. It's a 1500kv. Anyone have experience with these 2 motors? My goal is roughly 5 min run times with speeds ranging from high 50's to low to mid 60's. I'd appreciate any valuable input.
  • Rumdog
    • 6453
    Sprintcat .40s
    1527 1.5d on only 5s.
    With 6s and a mid thirties sized mono, you will be FLYING! I hit low sixties with this setup running a cc lv 240 and a x 457.
    • LarrysDrifter
      Big Booty Daddy
      • May 2010
      • 3278
      Sweet. I'm going with that one then. Thanks Ryan. Have to post a couple boats for sale, and I'm ready to rock. Amy timing suggestions?
      • Rumdog
        • 6453
        Yes, run between 5 and 10 degrees.
        • BHChieftain
          Fast Electric Addict
          • 1969
          Since you brought it up....
          What IS the difference between D and Y winds?
          Chief
          • fatboyelectric
            • Feb 2011
            • 84
            Originally posted by Rumdog
            Sprintcat .40s
            http://www.youtube.com/watch?v=TqTIEOKMnTA
            • Chris Harris
              • Oct 2007
              • 182
              As per Neu motors you should run the lowest timing on D wind motors. More timing will not do anything but increase heat.
              @BHChieftain. The D and Y winds use different winding patterns. The D's usually have a lot more wire and therefore much lower resistance and pull more amps. The Y winds have higher resistance but have more torque at a given Kv value and can size.
              Chris
              I.M.P.B.A. Record Holder P-Hydro 111.001mph Q-Hydro 120.192mph S-Hydro 139.233mph
              • LarrysDrifter
                Big Booty Daddy
                • May 2010
                • 3278
                Thanks guys. Have a 1.5d coming. Hoping for something kinda stupid with my future mono.
