View Full Version : Need help with ose water jacket
roadrashracing
05-20-2011, 10:27 AM
I am trying to put a waterjacket on my spartan motor but the o rings are breaking or poping out. I appied plenty of oil and am using a twisting movement, just really not a good morning.:ThumbsDown01::help::thumbsdown:
wilsta67
05-20-2011, 03:15 PM
if your using the stock motor you will need to remove the 3 screws at one end of the motor, you will not get the jacket to slip over them. and be carefull not to strip the socket heads of the screws use the correct size allen key to remove them. to assist in removing the screws apply a bit of heat to the heads using a lighter, this will melt the locktite holding them in.
Rcforever27
05-20-2011, 04:59 PM
You should also try using like dieletric grease i'n stead if oil . Oil will ruin the o rings.... If it's like motor oil or any petroleum based oil it'll ruin the o rings. They do go on kind of hard . Have one on the stock motor and one on my leopard that's currently i'n the boat. Also you might have to mildly heat up the screws on the motor to break the loctite loose. Good luck !
Rcforever27
05-20-2011, 05:01 PM
Oh sorry already mentioned the loctite trick above.... My bad....
roadrashracing
05-20-2011, 11:26 PM
I had the screws off, I tried greases and oils and all end up like pics, o-rings are junk now, any one know the size of them?
wilsta67
05-20-2011, 11:34 PM
it should slip straight on are you sure yo got the correct jacket?
wilsta67
05-20-2011, 11:36 PM
the jackets for the spartan motors or any other smooth case motor have a groove for the oring to sit in so im not sure how there comming out like that.
the jackets for the castle creation motors dont have a groove as the fins are on the motor to hold the orings.
roadrashracing
05-20-2011, 11:39 PM
yep
roadrashracing
05-20-2011, 11:43 PM
Is there such a thing as metric o rings? I don't remeber the size I got but it looked right on.
wilsta67
05-20-2011, 11:59 PM
yeas there is!
this is a leopard jacket i have that fits the spartan motor.
http://img14.imageshack.us/img14/1567/img0262og.jpg (http://imageshack.us/photo/my-images/14/img0262og.jpg/)
Uploaded with ImageShack.us (http://imageshack.us)
http://img196.imageshack.us/img196/2609/img0259hd.jpg (http://imageshack.us/photo/my-images/196/img0259hd.jpg/)
http://img402.imageshack.us/img402/9990/img0260yn.jpg (http://imageshack.us/photo/my-images/402/img0260yn.jpg/)
wilsta67
05-21-2011, 12:05 AM
take some photos of the jacket you have.
same angle shots that i just put up , and post them here so i can see.
wilsta67
05-21-2011, 12:07 AM
because if it were the correct one the jacket would just slip straight on with out any dramas at all.
roadrashracing
05-21-2011, 12:13 AM
pics
wilsta67
05-21-2011, 12:30 AM
pics
orings way to big
wilsta67
05-21-2011, 12:34 AM
take a photo of side without a oring
spartanonfire
05-21-2011, 02:08 AM
I agree....O-ring is too thick.
roadrashracing
05-21-2011, 09:32 PM
After 4th hardware store found the right orings and its metric.
