View Full Version : why are FE boats not using 4 or 5 blade prop?
fuse01
05-19-2011, 11:27 PM
i was just watch the miss geico ( real ones) and they have sick 6 blades props.
so the question is why are we not using 4 or 5 blades? what are the limitations ?
Ub Hauled
05-20-2011, 04:30 AM
I have a 5 blade prop and tried it... it turns out it would not hook... I believe that there is too much aeration.
05-20-2011, 07:24 AM
Small diameter multi-bladed props don't work well on most models. Two or three bladed props are the fastest. Some things just do not scale down well.
epsonjackson
05-21-2011, 03:51 AM
it would have been great if it could scale down well, 5-6 props would have been better
egneg
05-21-2011, 08:31 AM
The only one I know that has had any luck with them is graill. He used a pair of prop shop 8015/5's cut down to 65mm on the Platinum Princess. This is a 96" cat and the amp draw went up and run time went down. He said he would try them again after he got the turbines put in.
Chuck
Boaterguy
06-05-2011, 07:39 PM
It would be neat to try, maybe i'll get one for my rigger, just for looks and fun, would a 35mm/5 be about = to a x447?
Edit: I just went on propshop and I couldn't find any 5 blade, where should I look?
Punisher 67
06-05-2011, 07:54 PM
I once tried a 5 blade prop on my 57" Apache , I was an absolute turd.....in-fact it ultimately bent the 3/16 shaft from cavitation
jevmax
06-05-2011, 08:54 PM
Two primary reasons. Load and drag.
jcald2000
06-06-2011, 06:08 AM
And we turn our props a lot more rpm so the wake from preceding blade is disturbing the flow around the trailing blade. You won't see any 30,000 rpm shaft speeds on the big boats. At least not when I was racing them 20 years ago. LOL
Boaterguy
06-06-2011, 06:50 AM
Oh, so pretty much lots of aeration?
bigwaveohs
06-06-2011, 11:41 AM
Imagine the fun to S&B a 5-blade prop!
All you have to do is buy an Eagle Tree set up to test all the mods you make on your boats. Its the best part of boating in my opinion. This way any prop change will show the MPH and RPM so you can work from there. You just cant guess from "eye ball" readings.
Punisher 67
06-06-2011, 12:41 PM
Yes I lived through that , It was a challange .
Boaterguy
06-06-2011, 03:14 PM
How is it done?
egneg
06-06-2011, 06:02 PM
To modify a 5 blade and then S/B it is a real challenge. I did the work for graill's props.
Boaterguy
06-06-2011, 06:47 PM
Where'd he/you get them?
graill
06-06-2011, 07:13 PM
Chuck
True the big dog churned something fierce until you get the thing running then they bite in, out of 12 runs using the 5 blade only 3 had a really great top end over 90, the rest were churn runs regardless of the depth and angles. 5 blades look great for display but in practice, exhibition runs are all your going to get as the 5 blader will decide when they want to finally bite in.
That said Chuck did a great job on them and they do work, just do not look to set any records with them. great for cruising.:smile:
Note: Picked them up at Das boata after some wheeling and dealing. Real Prop shop props are getting hard to find nowadays, i sucked up alot of them a few years back to have on hand.
graill
06-06-2011, 07:27 PM
Like a few folks have already pointed out scaling down the big stuff doesnt always work, that and the "Theory" (damn the theory!!)prevents the cool stuff from being miniaturized and working well, most often props.
What is the theory? look it up, a couple of race folks provided some great info on it a year back or so, it is some great reading.
Boaterguy
06-06-2011, 07:29 PM
I just want to get one for cruising on my rigger, i'll find a cheap one and do 12 hrs of work on it, after that, I don't want to work more on it :(
Edit : You guys got me wanting a nice 5 blade!!! the smallest I can find is 120mm!!! :(
dasboata
06-06-2011, 07:49 PM
I have some 55mm 5 blades email me if interested
egneg
06-06-2011, 08:21 PM
I think you would be better off with a V series prop.
Boaterguy
06-06-2011, 08:26 PM
I have a good prop, I just want this for cruising and looks
egneg
06-06-2011, 08:29 PM
IDK ... the V series looks pretty darn good as far as a scale prop goes.
fuse01
06-06-2011, 08:59 PM
yeah 5 blades.. looks darn cool ... especially for demo purpose ...
can i get 1 too? wish to put it on my geico and maybe power it on a small motor to cruise around the pond and enjoy the scale look
Boaterguy
06-06-2011, 09:59 PM
I didn't get it, You can email him, he said 75$ shipped, S + B + P
Punisher 67
06-07-2011, 01:48 AM
How is it done?
Really no different than a 3 blade just more blades to balance on a 5 blade
iamandrew
07-09-2011, 06:46 AM
I dont mean to annoy everyone in this post, but having seen the 200kmph boats, they are all using 5 blade props
Punisher 67
07-09-2011, 05:11 PM
True enough but as mentioned already scaling propelers down doesn't always guarantee they will work as good as there full sized counterparts
tdjhutch
07-10-2011, 07:52 PM
its the size of the water molecule that stops props from scaling down & being effective
