View Full Version : "Unleash The Beast" Blackjack Build
Seacraftarioch
05-15-2011, 07:38 PM
Im starting with a pretty much bone stock BJ26, with afew mods and upgrages here and there. The theme is going to be Monster Energy/ DC Shoes. Sofar i have primed and laid down the base coat of color on the canopy and the primer and base coat of color on the hull.
Rough sketch of my idea:
http://i605.photobucket.com/albums/tt131/Roadmasters/Monsterboatbuild184.jpg
Temporary hatch (will be replaced eventually by one from tiqueman) with first coat of paint:
http://i605.photobucket.com/albums/tt131/Roadmasters/Monsterboatbuild188.jpg
Graphic that will be on the bow of the boat (shown on my dads BJ):
http://i605.photobucket.com/albums/tt131/Roadmasters/Monsterboatbuild185.jpg
Some pics of the hull, one side has a run that i need to fix but other than that i think it looks pretty good:
http://i605.photobucket.com/albums/tt131/Roadmasters/Monsterboatbuild186.jpg
http://i605.photobucket.com/albums/tt131/Roadmasters/Monsterboatbuild187.jpg
Ordered 2 octura auto bailers and a thru hull for the water cooling today also.
More in afew days when this coat of paint drys
bwells
05-15-2011, 08:26 PM
Good theme and nice paint job, looks good! Ouch on the auto bailers.
Boaterguy
05-15-2011, 08:55 PM
Yeah, but I think you should just tear it out and throw in some nicer stuff
bwells
05-15-2011, 09:06 PM
:confused1:
Seacraftarioch
05-15-2011, 09:13 PM
Explain?
Boaterguy
05-15-2011, 09:20 PM
did you buy it RTR or just the hull? sorry i've never owned a BJ but I haven't heard good things about the RTR stuff it comes with. I just read my post again, sorry, it was worded strangely)
Seacraftarioch
05-15-2011, 09:28 PM
RTR, its my first fe, sofar the electronics seem pretty good, but i have read that the esc will eventually have to be replaced (im considering the seaking 180a)
bwells
05-15-2011, 09:42 PM
Be sure and read the thread entitled "fixing the BJ handling issues" and pay close attention to the turn fin part. From what I have read, the motor is bullet-proof, haven't read anything bad about the ESC but get yourself the program card and share it with your dad. I really like your theme, colors are vibrant.
Seacraftarioch
05-15-2011, 09:58 PM
Done, done, and done lol. Thanks, it was monster or subway, i thought monster may look little better, so i went with it. So what is the ouch on the auto bailers?
wparsons
If I were you, I would buy the upgraded strut/rudder and ditch the steerable outdrive.
http://www.horizonhobby.com/Products/Default.aspx?ProdID=PRB2824
and
http://www.horizonhobby.com/Products/Default.aspx?ProdID=PRB2825
Not sure if you need a new flex/stub shaft, but if you compare the driveline parts between the BJ26 and the BJ26SS you'll find the differences.
bwells
05-15-2011, 10:07 PM
You should never need auto bailers, if you do you have other issues to address. One more hole in the hull and the spring/ball can get stuck open with the slightest bit of dirt/sawdust. IMO
Seacraftarioch
05-15-2011, 10:36 PM
and
I got the 2.4ghz version, it comes with a strut and rudder and not the outdrive, thanks though
Bwells:
Idk what im going to do yet, Ive gone over everything twice, only thing i havent done is tape the hatch and i still get abit of water in. If i keep them well maintained they should do their job correctly, right? When i get them in my hands ill make a decision. Worst that could happen is i have some fiberglass repair to do i guess
Make-a-Wake
05-15-2011, 11:00 PM
Getting a "bit" of water in is better than drilling holes for bailers that really arent needed. Water may be coming up your stuffing tube.................is it so much water each run that it will put the electronics in danger???
marko500
05-15-2011, 11:06 PM
I had auto bailers in some boats in the past. I had nothing but problems with them. Tape the hatch, check cooling system for leaks, seal all hardware and seal the stuffing tube and she should stay dry.
Mark
Seacraftarioch
05-15-2011, 11:23 PM
I guess i should have asked the question before i ordered. I didnt think it could be as much as i am getting from just the hatch. ive greased the flex shaft, put a peice of cooling tube over the stuffing tube/shaft, checked the cooling system for leaks, checked hull for cracks, i havent sealed the hrrdware bolts, but they were all tightened down well, ill seal them when it goes back together though. What could i have missed? Here is a vid a made of the leak, i have greased the shaft since then, it reduced the water a small amount but not by too much.
http://www.youtube.com/watch?v=iQt-VtlWmD4
I was getting same amount of water with hatch on also. Im not shure if the video helps much though
marko500
05-15-2011, 11:46 PM
Well that's the problem there's no hatch on that boat!! :just-kidding:
Did you pressure check the cooling or just visually check it? I've been having better luck with a piece of shrink tube over the stuffing tube/flex. The cooling line seems to wear out alot quicker. May have to toss her in the bathtub and check for the leak.
Mark
Simon.O.
05-16-2011, 05:53 AM
IMO auto-bailers are ambulance at the bottom of the cliff things.
Seal the hatch properly and IF water seems to come in via the shaft then put a small piece of kitchen sponge under stuff tube entry in the hull near the coupler and all will be fine.
All but one of my hulls come in bone dry after any run including being towed in upside down :smile: The Canard has a tiny leak and I am buggered if I know where the water is coming in from but I'll find it and fix that too.
Seacraftarioch
05-16-2011, 06:21 AM
Mark
i pressure tested it. Hopefully its just the hatch, but ill put on the shrink tubing too
Boaterguy
05-16-2011, 07:00 AM
You could put it in a tub, and dye the water, as soon as you see water, pull it out, you should be able to see where (about ) it came from
Seacraftarioch
05-16-2011, 08:29 PM
canceled the order for the auto bailers, thanks Steve!
Seacraftarioch
05-19-2011, 10:18 PM
Alittle more painting done:
http://i605.photobucket.com/albums/tt131/Roadmasters/c304a5e6.jpg
http://i605.photobucket.com/albums/tt131/Roadmasters/d2761216.jpg
marko500
05-19-2011, 11:50 PM
That looks fantastic. :thumbup:
Mark
