View Full Version : R2 rigger rebuild
steamboatbob
05-15-2011, 12:14 AM
Hi guys
(note to admins im just rebuilding this rigger and posting a few photos to show how i did it as i know lots of people out there got one of these and this is what i did so if you ant to move this post or deleete it feel free)
I just want to let people know what they are in for
cheers
bob
ok after a few weeks now of running my R2 hobbies rigger i am starting to see water in the hull and quite frankly i am really unhappy with a few things in the boat (sponson tube positions, people giving outrageous statements of what speed their boat has done, lack of room and flimsy build quality.)
essentially i am going to run a leopard 4074 2150 KV motor turnigy 180 esc and run it on 14 V if it kills me or i spend way too much it will be a learning experience for myself.
to start with i have here a pic of the motors i have the small feiago and the swordfish motor have been tested but they both really lack the punch that i need.
i only ran the blue swordfish once and my coupler that was supplied with the kit busted a pooper valve and refused to grab the cable. first problem, then the second problem was noticed water was inside the rear sponsons so i had a leak :ThumbsDown01:
http://i231.photobucket.com/albums/ee84/steamboatbob/R2%20Hobbies%20outrigger/15052011391.jpg
this is what i have done this morning first taken of the rear sponsons and please note i have not used any cutting tool at all to do this so this is how POOR the glue they have used is, i just used my fingers to push the pieces apart. the glue cracks easily and pulls apart.
http://i231.photobucket.com/albums/ee84/steamboatbob/R2%20Hobbies%20outrigger/15052011392.jpg
http://i231.photobucket.com/albums/ee84/steamboatbob/R2%20Hobbies%20outrigger/15052011390.jpg
i decided to pull the sides of the tub off this was easily done by using a thin wedge rudder and gently pushing down like this
http://i231.photobucket.com/albums/ee84/steamboatbob/R2%20Hobbies%20outrigger/15052011393.jpg
now after all this has been done the hull looks like this, very workable and i can surly force in my nice big leopard motor where i want it, please note i have ripped out the motor mount and replaced it with a water cooled one funnily enough the ply for my engine mount had already started to delaminate due to water getting to it.
next job to do was to get the sponson tube holders into a lower position so a battery can fit up front and adjust the position that the front one is at so it can be a bit more forward of its current location to fit a larger battery as the current batteries i have are 145 mm long (Zippy 40c series 5000 mah 2 cell). so i have removed the aluminium tubes and will glue them in to place after i have cleaned up the central tub skeleton a bit
http://i231.photobucket.com/albums/ee84/steamboatbob/R2%20Hobbies%20outrigger/15052011394.jpg
cheers guys i hope you like this one
steamboatbob
05-19-2011, 05:40 AM
ok a little bit got done today at work i have dropped the height of the boom tubes in the tub and repositioned them so that i can put a 14.8 volt battery or 2, 7.4 volt batteries in. The aluminium tubes are resting flat on the bottom of the hull and i will fix these in with a bit of 24 hour araldite and a small amount of CF tape
due to the weakness in the hull itself i have gone a little drastic and ordered some carbon fibre tape 5 meters at 100mm wide which i will use to strengthen the tub and after careful looking at the booms i have ordered some carbon rods (not the tubing that is supplied) as i noticed that some of the tubing had started to crack where the grub screws connect. also have given the tub a real good sanding using a bit of 80 grit for the upcomming day or 3 of epoxy work inside and out. and also to get rid of the excess glue that is there
http://i231.photobucket.com/albums/ee84/steamboatbob/R2%20Hobbies%20outrigger/19052011395.jpg
http://i231.photobucket.com/albums/ee84/steamboatbob/R2%20Hobbies%20outrigger/19052011396.jpg
Brushless55
05-19-2011, 11:00 AM
nice skills man
looking forward to your new better rigger :beerchug:
siberianhusky
05-20-2011, 09:33 AM
Should be good with the rebuild.
Thats the way I build my ultralight JAE tubs, 1/16 ply open framework covered in 1/32 ply, with a couple more doublers for boom and motor mounts. Makes a light strong hull.
steamboatbob
05-23-2011, 03:09 AM
oh well a day off work under management orders, feeling a bit under the weather but not sick enough to do a little work on my boat so in the last few days i have basically taken apart the sponsons and it looks like they have been put together with superglue so i have reglued the ribs inside the sponsons to give them a little more strength and like the main tub the glue cracks apart very easily and cleans up really easy. I use waterproof PVA that I use to make solid timber benches for kitchens so atm i have redone them and used some epoxy to hold the sponson tube holder in place when this has cured i will coat the sponsons with resin and fill it with foam.
Things to do
- Resin central tub
- CF central tub
- Realign and install hardware (Motor, driveshaft)
- make a new cowling
- make a ski instead of rear sponsons
http://i231.photobucket.com/albums/ee84/steamboatbob/R2%20Hobbies%20outrigger/23052011399.jpg
http://i231.photobucket.com/albums/ee84/steamboatbob/R2%20Hobbies%20outrigger/23052011400.jpg
siberianhusky
05-23-2011, 07:50 AM
Too bad they don't sell that as a kit! Looks well engineered and cut, just did a piss poor job of assembly at the factory. A couple of changes for battery location and they could have a killer kit!
That is a much more difficult method of building sponsons than cnc cut foam skinned over with ply.
Strange! That much effort in some aspects, almost none in others. What goes on in the heads of the QC people over there?
steamboatbob
05-23-2011, 09:24 AM
i agree with ya husky they should offer it as an unbuilt kit but the sposons are an easy build as it is all tabbed anyone with a set of clamps, masking tape and a bit of patience would be able to do a nice build but a block of solid timber to place a turn fin on would be very nice indeed
steamboatbob
05-26-2011, 06:14 AM
well the carbon job has started i am just going to put 1 layer of unidirectional tape on the tub to give it a bit of support but mostly im oing it for the look and this is something i want to try out
found a few great videos from the following website on layering carbon fibre over anything, they use their own products but it seems that it will be the same if i use someone elses products
http://www.carbonmods.co.uk/Products/Carbon-Fibre-Skinning-Starter-Kit---Large__CMCFSK1000.aspx
for the carbon fibre i am using west system 105/206 and i'll see what i can do for the top coat.
also i am laying the carbon fibre down and letting it harden on each side and trimming it square before i do any top coats as i want the topcoat to be done in one hit if possible
and here we are at present, I did find that a small offcut of carbon tube for my outrigger was an excellemt tool for pressing the CF down onto the hull
and this is the result sofar :bounce:
http://i231.photobucket.com/albums/ee84/steamboatbob/R2%20Hobbies%20outrigger/P5230060.jpg
martin
05-26-2011, 09:16 AM
The most popular way to press down carbon or glass cloth is with an old credit card. After applying the cloth & resin use the card held at around 30 degrees as a squeegy & pull it over the carbon. This flattens the cloth & removes any air bubbles but more importantly removes excess resin from the lay up making it lighter. Martin.
steamboatbob
05-26-2011, 09:39 AM
well ill have to agree to disagree with you on that note mate i have used the credit card method before and had very good results but as the CF was unidirectional the idividual strands were dragged off line and looked bad i did start off with a credit card on this but had to quickly change method while doing this. The roller principal has the same effect as the card removing air bubbles and excess resin. and here is the side done after trimming it back flush to the hull.
http://i231.photobucket.com/albums/ee84/steamboatbob/R2%20Hobbies%20outrigger/P5230070.jpg
http://i231.photobucket.com/albums/ee84/steamboatbob/R2%20Hobbies%20outrigger/P5230071.jpg
siberianhusky
05-26-2011, 09:45 AM
I like that! Looks awesome and it's functional! Best of both worlds!
steamboatbob
05-30-2011, 06:29 AM
just a few more pics of the carbon going on and the coathanger trick i used to keep the hull out of contact with everything.
same process as befor but the winds picked up at home and the temperature dropped dramatically so i put it on a clothes hanger in front of my gas heater to keep the temperature nice and steady
Just need to do the top of it and all will be good:olleyes:
http://i231.photobucket.com/albums/ee84/steamboatbob/R2%20Hobbies%20outrigger/30052011404.jpg
http://i231.photobucket.com/albums/ee84/steamboatbob/R2%20Hobbies%20outrigger/30052011403.jpg
http://i231.photobucket.com/albums/ee84/steamboatbob/R2%20Hobbies%20outrigger/30052011405.jpg
martin
05-30-2011, 08:58 AM
One of the best tips i was given many years ago for curing epoxy By someone i knew who was a world renowned Rc pylon racer who used to manufacture carbon & kevlar planes & boat hulls for other manufacturers was to use a heater box. This was a simple insulated box of whatever size you needed to build that had a common household light bulb inside the box. The wattage of the bulb dictated the temps it could reach, Youd be suprised at the temps reached with just a 60w bulb, This cured the resin fast & very hard that didnt leave that slight sticky feel that you sometimes get ecspecially if its a bit of a damp atmosphere your in. Epoxy likes a nice constant temp but not to high & dry atmosphere. He also used to vacuum bag his mouldings as well. So basically it done the job of an autoclave. I never vacuum bagged mine just used it to dry the resin. Box was just made of polystyrene sheet 1" thick with just a polystyrene top that lifted off. Martin.
martin
05-30-2011, 09:10 AM
From memory i used to cure at around 90F but could easily go to over 100F with say 100w bulb fitted. The bulbs gives nice steady heat. Martin.
ray schrauwen
05-30-2011, 01:35 PM
Nice thread. Thanks for doing a tear down of the rigger.
I added MAS epoxy to the inside of my hull but, never thought of doing this kind of tear down.
Since mooving the boom holders in the tub, are the sponsons deeper now?
steamboatbob
06-01-2011, 06:23 AM
yes i moved the sponsons down about 10mm (just under1/2 inch) in the central hull thus the hull will sit taller when on the plane.
but have applied a secondary coat of epoxy to the main tub and decided that the top will be painted as it will be a bit difficult to get the CF along the narrow parts and with the lefover CF i am thinking the sponsons might get a bit but i am starting to wonder about how much weight i am adding to the hull and dont want to go overboard as i cannot remove that much from it.
Second layer of epoxy went on nicely using the card trick (bit of scrap ABS)
I'll post a photo soon but nothing looks different atm
siberianhusky
06-01-2011, 07:22 AM
Remember to re attach the rear sponsons the same amount lower or it will have some serious running attitude problems, the angle of attack on the sponsons would be way to steep if the front of the hull is a 1/2" higher than the back.
martin
06-01-2011, 09:16 AM
Your better off painting hydros as you can then use bright colours, So much easier to see them at speed. Martin.
ray schrauwen
06-01-2011, 01:38 PM
Cool. I didn't know if I could do that without doing itto the sponsons also.
I'm going to drill a hole or two in my front sponsons or crack one side open, add epoxy to seal and spray foam to fill.
I'm not too worried about weight, if it's too heavy for spec power then I'll add some steroids to it :w00t:
I might put a ski on mine instead of rear sponsons... we will see...
steamboatbob
06-13-2011, 07:42 AM
just letting you guys know that things are transpiring her but with the cold weather settling in nothing is really getting done i have reattached the rear sponsons and im halfway through giving it a lick of paint the front sponsons will be my next thing and also sorting out the hardware and driveline Grim racer turn fin was attached to the right hand sponson inside the box to make it a little more solid and i will CF the tops and backs of the sponsons to give it a little strength and good looks.
The hull and motor weigh in at 1131 grams atm so i am on track for the moment
http://i231.photobucket.com/albums/ee84/steamboatbob/R2%20Hobbies%20outrigger/13062011410.jpg
sailr
06-13-2011, 08:26 AM
:roflol: Quote "busted a pooper valve" Unquote:banana:
sailr
06-13-2011, 08:32 AM
:popcorn2:Your wife's gonna be pissed if you get epoxy on that beautiful teak table!
sailr
06-13-2011, 08:33 AM
Thanks for this informative RE build. I had considered one of the R2 riggers but now I believe I would rather build a JAE kit!
T.S.Davis
06-13-2011, 09:33 AM
You've actually managed to inspire me to build another rigger. Thank you sir.
steamboatbob
06-14-2011, 06:29 AM
well after pondering this arvo i put on my first clear coat
and Sailr i refinish that table once every year due to my working on it
http://i231.photobucket.com/albums/ee84/steamboatbob/R2%20Hobbies%20outrigger/P6110082.jpg
http://i231.photobucket.com/albums/ee84/steamboatbob/R2%20Hobbies%20outrigger/P6110081.jpg
http://i231.photobucket.com/albums/ee84/steamboatbob/R2%20Hobbies%20outrigger/P6110079.jpg
steamboatbob
06-14-2011, 06:31 AM
and the pink paint was for my daughters dolls house i built her, the little cherub just turned 5
steamboatbob
06-24-2011, 09:24 PM
next problem i have is with the hardware and i need a little nudge in the right direction, the 4mm shaft and square drive that came with the rigger is badly ballanced and in my honest opinion deserves to go to the bin and i am unsure of what type of shaft arrangement to go with 1/8 or 3/16 could someone point me in the right direction as i would only need the strut, flex shaft, drive dog, preferably pre assembled. it will be connected to a leopard 4074 2200KV on 14.8V
the other mod i have been working on is modifying the turnigy 180 ESC cooling block trying to find some 90 degree elbows that are nice and big is a trial in itself i hope that OSE get some of the leopard 90 degree cooling fittings with the m5 fittings in their next order. It is a basic job to unscrew the old cooling fittings and screw in the 90 degree elbows off the leopard motor cooler and they are a much larger internal diameter than any other on the market but also impossible to get. the main reason for this is i want to rotate the esc 90 degrees iside the hull so that the caps and the wiring are not touching the sides of the hull here is what im trying to do in the photo below and it gives me 5mm clearance either side of the esc in the hull, so it is a neccesary job to do, and with the straight fittings it is impossible to turn the speed control as i would be putting a kink in the cooling tubing.
Cheers guys and i hope you ordered the fittings steven as i want them badly :Praying:
BoB
http://i231.photobucket.com/albums/ee84/steamboatbob/R2%20Hobbies%20outrigger/25062011415.jpg
martin
06-25-2011, 04:51 AM
With the 4074 motor you deff need 3/16" flex, A 1/8" is much to small. Martin.
steamboatbob
07-22-2011, 04:21 AM
well after the weather gods gave me a bit of sunshine i did my final coat of resin to the sponsons,
also done since my last post
- installed hughey 3/16 flex shaft (had an old crumbgrabber strut and rudder from fullers)
- installed motor mount
- installed brass tubing
- installed 90 degree elbows to the esc to turn it 90 degrees inside the hull
- made improvements to the hatch by putting a few blocks of balsa onto the origional one and the put a layer of resin on it i still need to clean it up and spray it but i wil do that when i spray the sponsons)
- moved the rubber bellows for the servo to the back of the boat instead of being inside
- finished off the main tub and gave it a used look by sanding the paint back quite a lot down to the ply in some areas and coated it with clear
- purchased a Garmin E-Trex H to give me a good indication of how fast it goes i had my friends 1 Mtr land yacht at 20 KPH
With the teflon tubing i received with the flex shaft i found it to be a little oversized so i got some tighter teflon and put that inside the teflon tube at the top bottom and middle of the teflon that i got with the flex shaft resulting in a teflon liner that can hold a bit of grease and still be free enough for the drive shaft
and here are some pics if you guys want a more detailed pic of what i have done yell out and ill get it up for you
question for the day "is a bearing at the motor going to change anything and if so what sort would be best suited for this boat"
Cheers guys and I really appreciate the help and comments that have been posted here
http://i231.photobucket.com/albums/ee84/steamboatbob/R2%20Hobbies%20outrigger/P7190094.jpg
http://i231.photobucket.com/albums/ee84/steamboatbob/R2%20Hobbies%20outrigger/P7190095.jpg
http://i231.photobucket.com/albums/ee84/steamboatbob/R2%20Hobbies%20outrigger/P7190096.jpg
steamboatbob
08-05-2011, 09:40 PM
Well after a long awaited time i can clap cheer and make a fool of myself
It's ready for the water
hopefully this arvo i will be able to video some footage for you guys
http://i231.photobucket.com/albums/ee84/steamboatbob/R2%20Hobbies%20outrigger/06082011439.jpg
steamboatbob
08-06-2011, 06:19 AM
http://www.youtube.com/watch?v=tvT6l0EG7fo
well it seems i have well and truly underproped this bugger so please help me out here guys i was running a X438 and it was cavitating massivly motor and esc did not have any temp issue as it was cold as when i checked them as well as the batteries
so tell me what you guys would recommend for this rigger and we shall see what it can do in a bigger lake
steamboatbob
08-08-2011, 08:08 AM
srry to be a pain but can someeone help with prop selection for me i was thinking either a 1745(3) or an x445(3) but really dont know what to go for the video above was with an X438 on full throttle but it needs to go bigger so help on this front would be awesome
carlcisneros
08-08-2011, 08:43 AM
try a x442 first then 1445, x445 or an ABC 1616. all 2 bladed props.
steamboatbob
08-09-2011, 07:28 AM
thanks for that carlcisneros
steamboatbob
09-03-2011, 06:18 AM
ok here is todays video i will post another higher quality one soon windows movie maker killed my video quality
running
leopard 4074 2200 kv motor
turnigy 180 AMP Esc
14.4V Flightmax batteries 2*2 7.4V in series
Fullers hardware Crumbgrabber hydro/rigger set 3/16
X445 prop
http://www.youtube.com/user/MrSteamboatbob#p/a/u/0/l9OLXuMKw7o
