View Full Version : new leopard 4082 vs used
Shaun78
05-12-2011, 06:07 PM
New one is hard to spin by hand and my older one spins much easier. Is it worn or just broken in?
m4a1usr
05-12-2011, 08:57 PM
Which 4082? The 2200kv .5Y leopard is known to have some heat issues. It might have a demagnitized rotor. On the other hand its probably alright. I used to worry about equal size motors having the same "cogging" feel. I spoke with Neu about this and they stated its not that simple. Only way to know is to connect each motor to a equal voltage source and do a kv check. If they both spin the same rpm at the same voltage then they are in essence equal motors. I didnt like that answer because it seems to me that there is something else going on but when the factory engineer tells you this, well I guess I have to believe him.
John
scoota
05-13-2011, 05:26 AM
John
I had heat issues with my 4082 in my DF33 , i drilled vent holes in the end bell like a NEU motor , with very good results !!!!
m4a1usr
05-13-2011, 04:18 PM
I guess an easy way to tell if one of the motors has a demgg'd rotor is take the face plate off both and put the rotor out of the one that feels stronger in to the one with the weaker feeling rotor. Might know right off the bat by exchanging rotors.
John
bbosncali
05-13-2011, 05:15 PM
The one with less resistance runs great. He's running consistant 60mph passes but I recently ordered a 4082 220kv and not using it at the time so I gave it to hime to try on 5s and he was only getting mid 50's the other motor that he is using is a 1500kv 4082 on 6s. Now according to my calculations he should be spinng about 4500 more rpms with the 5s setup as aposed to the 6s setup which leads me to believe that they need to be broken in. Temps were still good on the 2200kv only around 100 so its not getting that hot. The 1500kv spins almost freely and the 2200 has a ton of resistance.
m4a1usr
05-13-2011, 05:32 PM
Thats weird? You wouldnt think there would be any difference. I know the Neu series motors all use the same rotor. So a 1515/.5Y and 1515/5D (if theres such a critter) all share the same rotors as long as the case length is the same. The winding version has no bearing on which rotor goes in. Same with the Castle 1512 series. The 1Y and 1.5Y share the exact same rotor. So you would think the same of the 4074 series and the 4082. I dont know about the stator plates though. You would think the stator length stays the same, so the magnetic attraction would be similar. The variable could be the air gap should the ID be different.
John
bbosncali
05-13-2011, 05:39 PM
Well there bothe 4082 just one is a 1500kv and the other is a 2200kv. Same size motors. It just seems that they have to wear in. To me its like anything if there is resistance then its not going to be upto optimal power. I could be wrong but that's my theory
Jabbo
05-13-2011, 07:40 PM
Just got my leopard 4082 2200kv and is also very hard to turn. Put it in my genesis hopefully can run this weekend let you know how it goes compared to my neu 1515 1y 2200kv that I had in it before.
bbosncali
05-13-2011, 07:42 PM
That's what he put it in was his genesis. With a x642 on 5s and only got 55.something but I consistantly running 60 wth a best of 63.7mph with his 4082 1500
Jabbo
05-13-2011, 08:07 PM
I was ruining 54.7mph in my genesis on my neu with an x645on 4s 2p so it will be interesting to see what the leopard does with the same set up.(i have my neu in my pursuit now and it runs sweet.)
bbosncali
05-13-2011, 08:42 PM
Well I've run a 4074 2200kv 4082 1250 kv cc 1512 1800 and a tacon 4074 2000kv and I'm running a cc 1518 1800kv in it this weekend. So far my tacon has ben the fastest with 63.4 mph wth a x642 crappy run times but it was fun running on 6s. I have high hopes for the cc1518 though
Jabbo
05-13-2011, 10:39 PM
Can you suggest a good 3 blade prop because I get a lot of torque roll with the 2 blade prop.
Thanks
Jeff
bbosncali
05-13-2011, 10:44 PM
What size props are you using?
Jabbo
05-14-2011, 12:31 AM
X645
bbosncali
05-14-2011, 12:33 AM
That's a big prop with a lot of pitch. What motor and boat are you using it on?
Jabbo
05-14-2011, 12:49 AM
In my genesis leopard 4082 2200kv(was a neu 1515 2200kv)(see post 10)4s2p
bbosncali
05-14-2011, 01:02 AM
Ohh my bad... my buddy is running a leopard 4082 1500kv with an x642 and runs really nice smooth and fast 60mph consistant with a best of 63.7mph but like I said in earlier posts I gave him my brand new 4082 2200kv to try on 5s and his best was 55.6mph or right around there. He didn't change a thing except the motors and it was slower which makes me think the motor needs to break in. If you run an x642 and raise your strut you'll be surprised how much faster it is. He used an m445 and it was quite a bit slower cause he had to drop his srut for it to fit. The x642 barely clears his rudder bracet right now and that thing screams!! He has no torque roll at all. I don't personally have any experience with 3 blade props I have 6 different props m440 x642 s220 m445 m545 and an m645 so far my 2 favorites are my x642 and m445
Jabbo
05-14-2011, 07:25 AM
Thanks for the info.
Jeff
