View Full Version : Esc and motor??
moore4x4
05-12-2011, 07:28 AM
Want to upgrade my boat what's a good esc and motor to run in my fastech??Oh it's brushless now. Want to stay with brushless
LiPo Power
05-12-2011, 08:44 AM
If it's brushless now, what motor do you have now in it and what EsC?
Was it converted from nitro maybe?
moore4x4
05-12-2011, 09:28 AM
Yes it's brushless now. Came stock with brushless. It's all stock haven't did any thang to it.
LiPo Power
05-12-2011, 04:43 PM
The best motor for this boat is this one:
http://www.horizonhobby.com/Products/Default.aspx?ProdID=PRB3310
The best ESC for this boat is this one:
http://www.horizonhobby.com/Products/Default.aspx?ProdID=PRB3309
..and this is one of the best set ups out there, do not change it!
If you need to go faster use 2 x 2S 5000mAh or larger, 30-40C lipos and x645 prop.
If you willing to start playing arround with more voltage and larger props use 120Amp ESC with stock motor. remember, you have one of the most popular motor fot this kind of application out there and it will work fine with little higher voltage if you decide to go that way..
moore4x4
05-12-2011, 04:52 PM
Thanks I got some 6000 lipos for it today to try. Going to look for the prop now. Thanks for all the info.
moore4x4
05-15-2011, 07:33 PM
What do I need to adjust to get the nose out of the water. Trim tabs or out drive??
3rcman
07-18-2011, 01:20 AM
run ul1 esc and motor 2015kv i think,on 4s.stock stilletto prop,41-44mph,things insane
LiPo Power
07-18-2011, 12:53 PM
Do you have a video with GPS that you can post here for us to see?
HELI-MD
09-02-2012, 07:57 PM
I had my stock impulse 31 motor and esc lying around so I threw them in. It soom to go great don't have gps speeds but the 1800kv is a noticeable difference for the better.
