View Full Version : Accucel 6
Boaterguy
05-11-2011, 03:55 PM
I have an accucel 6, and it is rated at 11-18 v, max 6A. one of my computer adapters is 14v, but the connector is too big, can I run it on my 18.5V one? or is that pushing it? also, what is the amperage of a car batt?
Boaterguy
05-11-2011, 04:30 PM
Also, do I balance a 4000mah battery at 4A? just as I would be charging it?
HYDROJERRY
05-12-2011, 07:08 AM
Im not a big time electrics guy but i ballance charge my 5000's at 5a, then the ac6 will lower the power as it charges, or mine does.
sailr
05-12-2011, 11:23 AM
Not sure I'd push that many volts into that charger!
sailr
05-12-2011, 11:25 AM
You can get a great deal on power supplies here. Best deal going! Get one of his and add your own connectors. I have two of his 47A supplies wired in series for 24V to drive my Hyperion 720 duo. With 24V you can charge two big packs simultaneously.
http://www.feathermerchantrc.com/
Boaterguy
05-12-2011, 04:28 PM
so 18.5 is too much? i can probably get a connector and just solder up the adapter cord.
