View Full Version : Repaint after repair
yachtsystems
05-08-2011, 10:12 PM
Still thinking about final paint but this is the progression.
lectriglide
05-08-2011, 11:24 PM
Good start! Check out what a few accents items can do.
http://forums.offshoreelectrics.com/showthread.php?t=24505
Oh, and if you haven't already, reinforcing the canopy is a MUST.
yachtsystems
05-09-2011, 12:25 AM
Pulling most of my supplies from the professionals around me. Cool stickers though. Just trying to stay inside the lines on such a small scale....:) I used Awlgrip with a reducer and a metal flake.
yachtsystems
05-09-2011, 01:01 AM
Seems that replacing the magnets with quick turn fasteners would be a good choice? Thinking of adding a third one in front and filling the factor "pin" mount, thoughts?
brian6989
05-09-2011, 01:06 AM
I installed the rear kintec quick locks for the hatch and for some reason they are very hard to get to lock seems like they should be a couple mm longer but its a great idea
brian6989
05-09-2011, 01:09 AM
i also tryed shimming them as well with no luck... maybe I missed something
yachtsystems
05-09-2011, 01:22 AM
I have ordered the Kintec fasteners. I had planned to bed their height with epoxy/fiber. Am I in for surprise?
yachtsystems
05-09-2011, 01:26 AM
I am confused. Did you set your lid level and shim/dry fit the base prior to installing the base peice? If so, what went wrong?
CHIEFY_44
05-09-2011, 02:22 AM
i put 1 quick latch on mine but i bought 2 and used the nut off the second to adjust the height so it fit correctly
wppracing
05-09-2011, 05:17 AM
I had to shim the insert higher also.
http://i243.photobucket.com/albums/ff79/wppracing/INSERT.jpg
ron1950
05-09-2011, 01:13 PM
nice work but still..dont forget to tape it lol
brian6989
05-09-2011, 02:55 PM
just a little fyi on the hatch pins I ran up to ace hardwere and the nut in the lamp repair section is the same nut as what comes with the pins I used it to adjust height up now works perfect kintec might want to include a extra nut since they wont work with out it
