View Full Version : mini airboat help
TheGnMan
05-07-2011, 07:47 PM
Hello to all as Im new to this forum. I have been into rc for 17 years but am new to boats. I bought my 11 yo son 2 boats for his b day last Mar. . He is a speed freak which I would say is my doing lol. The ul-1 ( instead of Spartan , thank god) I bought he loved but the mini alligator tours airboat was a dud for speed. So for a quick solution I put a traxxas vxl-3 motor and esc in it. I have no issues running it on 12nimh cells wired in series but when I just switched it to lipos this past week (1) 11.1v 1500mah dynamite pack the esc goes into a low voltage cutoff. This happens when Im wot for more than 2 or 3 secs the green light on esc switches to red and Im down to 50 percent power until I rearm esc. Does anyone have any ideas on whats up. Im wondering if its because this setup prob isnt designed for direct drive on lipos at least. Also there has been no overheating issues. Thxs for any response.
wparsons
05-08-2011, 10:13 AM
Is the LVC set correctly for 3s? What prop is on the motor? It might be that the battery can't supply enough current and that's why the voltage is dropping.
tim v
05-08-2011, 10:42 AM
i run the ame boat but i run 40 plus cs in it seems to work fine...
TheGnMan
05-08-2011, 11:31 AM
Thxs... The esc is set to lipo prop is stock 5.5 in by ? and this setup worked fine when I had it in a truck same packs too btw
tim v
05-08-2011, 12:04 PM
car to boat ....boat needs higher Cs.....
TheGnMan
05-08-2011, 01:53 PM
Good call Tim I plugged in a 11.1v 5050mah 35c pack and no problems except it dosent fit. I wonder if I make a 2cell pack from the 3cell pack I have if it will have the same issues because I dont have a pack that will fit with a higher C . The pack I will try this with is a dynamite 25c 3cell 1500mah. What do you think? That little boat is almost outta control anyway running on 3
tim v
05-08-2011, 02:44 PM
i run a 2200 mah 3 cell 40c works wicked.......
TheGnMan
05-08-2011, 03:56 PM
What brand, that pk must just squeeze in. I have been using all polyquest and poly rc pks this past year I will check to see what they have also. What motor are you using btw thxs
tim v
05-08-2011, 04:10 PM
turnigy nanotech 45-90c
TheGnMan
05-08-2011, 04:21 PM
What motor and esc are u using?
tim v
05-08-2011, 04:43 PM
mini traxxas and a turnigy 60 amp esc....
