View Full Version : how much gap
brian6989
05-07-2011, 03:56 PM
can someone tell me how much gap should be between white washer and the collet that holds the prop
bbosncali
05-07-2011, 05:37 PM
About 1/8-1/4 between the stuffing tube and strut which is what I think your talking about
brian6989
05-07-2011, 05:39 PM
ok thanks
CHIEFY_44
05-07-2011, 08:58 PM
if u mean between the white washer and the drive dog its around 1mm
bbosncali
05-07-2011, 09:21 PM
That's what proboat reccomends but its not enough for the flex shaft to flex. Should be the size of the flex shaft for space.
brian6989
05-08-2011, 01:21 AM
yes the white washer and the drive dog 1mm and 1/8 is quite a difference is this something everyone runs different
TheShaughnessy
05-08-2011, 11:43 AM
hold the motor collet still with a wrench, turn the prop a little and you will see it compress, make sure your gap is enough to handle that compression. I'd go closer to an 8th inch.
brian6989
05-08-2011, 02:15 PM
ok thanks for the info
