View Full Version : Swordfish 240hv Programming
6sHyper
05-06-2011, 06:10 PM
this is my first swordy esc, Running cc1717, 6s2p, x646 prop, 35" DF mono. Can anyone tell me what my setting should be? I have the program box, just dont know what some of the things mean, like the pwn??
6sHyper
05-06-2011, 06:57 PM
well it doesn't seam that this program box even works?? wtf
Diesel6401
05-06-2011, 07:02 PM
Which box are you using the square one or the small tiny card.
drwayne
05-06-2011, 07:03 PM
what are you doing (wrong) ?
Id set
pwm 8
timing medium
lvc as per your batts .. and that's it !
6sHyper
05-06-2011, 07:25 PM
Diesel its this box:
http://www.offshoreelectrics.com/proddetail.php?prod=hef-programbox&cat=136
Diesel6401
05-06-2011, 07:29 PM
You have to plug in the esc to the box, add a rx pack to power the box and plug in your lipos to power the esc.
The setting dr.wayne said will be perfect
6sHyper
05-06-2011, 07:37 PM
It wouldn't read the esc, i tried like 10 times, so i decided to make you guys a video to show you exactly what it was doing and i'm literally filming it and when i plug in the 6v battery it friggin shows up as swordfish 240 and i programmed everything in! LOL.
I did as drwayne said, and for the other things i did soft cutoff, standard start, soft brake, i think that was it.
LiPo Power
05-06-2011, 10:30 PM
So you got it right?
Get the USB linker.
I have this ESC and with the USB linker it is easier than Castle ( well still have no data logger but the new version of it will have it )
Robert
6sHyper
05-06-2011, 10:58 PM
yes got it the Box worked like a charm once it finally recognized the esc! my run was a total nightmare though, but thats another topic, literally. check the build section, this esc might just be toast now after being submerged for 30mins.
