View Full Version : SeaKing 180 and P Mono
05-05-2011, 08:43 PM
I normally dont push my setups hard because we dont race much, so I'm looking to gauge whether or not I can use seaking 180 with a p mono setup.
Boat is a delta pirate knockoff with a 4082 2200kv motor.
MarkF
05-05-2011, 08:57 PM
Steven, I use my 180 with a Neu 1527 1D on 4s and 6s. I finally burnt it up on 6s and a saw set up so 4s is no problem. I think these are strong contollers for the money.
Mark
properchopper
05-05-2011, 08:58 PM
Steven, Hi !!
I run the Seaking 180 on my Insane 34" P-Mono setup with a Neu 1521 1.5D
(1900KV) spinning a 450/3 mildly tweaked by Mr. Sholund. The boat weighs 9.5 lbs rtr. After @ 2.5 min the motor is barely warm, the T180 is maybe 120 deg & the Etti cap board is @ 130. Mark F has run the same setup before with a 1527 on 4S with no probs with the SC (other than setting the LVC to "NO LVC" and cell count to autodetect) I have no hands-on with the 4082, but the T180 has proven rather nice on 4S- I even use the built-in bec.
ray schrauwen
05-05-2011, 09:36 PM
I run the 180 in my DF33 P-mono. I use a 1521 1.5D and a CMDI 5083 x3blade prop.
Sheyaaa! it hauls. The prop is really high compared to other P-mono's.
The caps get hot and I'm going to add more before I take her out again.
My temps are similar to above post by PropChopper.,
Make-a-Wake
05-05-2011, 10:11 PM
I run a T180 in my 39" DF knockoff(Vader) with a 1717 on 6s with an x447...........no problems. Had to prop down from x450 as weather warmed up.
Brushless55
05-06-2011, 01:15 AM
These speedos sound like tanks! :rockon2:
egneg
05-06-2011, 01:30 AM
I run a T-180/etti cap bank in my P-mono with 1515 1Y. Did great last season.
scoota
05-06-2011, 02:30 AM
Been running 4082 1500kv on 6s in a DF33 & X648 for well over 6 months , with not a problem , i LOVE these ESCs , good bang for your buck , oh i had the BEC disconnected since new . Did fit extra caps , and a cooling mod .
05-06-2011, 07:34 AM
Thanks for all the info guys. I added some caps like you did Scoota. It seems the easiest and cleanest way to do it.
crrcboatz
05-06-2011, 11:02 AM
What size caps did you use in those pics scoota? Steve do you have the caps?
05-06-2011, 11:08 AM
It do http://www.offshoreelectrics.com/proddetail.php?prod=ck-cap-35v-1000
