brian6989
05-03-2011, 02:37 PM
Can someone tell me what shaft grease they use and if it is available locally
ron1950
05-03-2011, 02:45 PM
proboat and aquacraft both have there own brand of greese either is the same
jac4412
05-03-2011, 02:49 PM
Anytype of grease you can get that isn't too "liquidy" but aren't terribly viscous will be a good pick. I use the proboat grease myself... With the adapter they give you that stuff lasts forever. If youre going to use store grease look for some sort of marine grease and simply lightly coat the shaft. You want a grease that allows the flex shaft to spin... but not heat up... or let in water. You can tell the difference, some mechanic grease is very thick and won't work. Some fine grease will simply run out. Find the medium!
brian6989
05-03-2011, 02:50 PM
ok thanks I was hoping to find some locally but if I have to order it I will
