View Full Version : Tacon Motor?
the5
05-01-2011, 07:51 PM
Tacon Motor?
Hello, I will be using this esc-
http://www.hobbyking.com/hobbyking/s...idProduct=8946
Turnigy Marine 120A Brushless Boat ESC
Constant Current: 120A
Burst Current: 240A
Resistance: .0007ohm
Battery: 2-6S Lipoly
BEC: 3A/6v
Motor Type: Sensorless Brushless
Size: 94 x 33 x 18mm
Weight: 91g
What kv motor should I get for 6s running. I am leaning to 1700kv for the speed increase.
1300kv
http://www.hobbypartz.com/96m811-3674--1300kv.html
1700kv
http://www.hobbypartz.com/96m812-3674-1700kv.html
LarrysDrifter
05-01-2011, 08:12 PM
Either motor will work. You might have more heat with the 1700kv, but you can try propping small. Also,use a separate BEC since running the esc at the max voltage rating. What hull is this going to be run in?
the5
05-01-2011, 08:29 PM
Spartan?
the5
05-01-2011, 08:30 PM
But, which one would you reccomend?
LarrysDrifter
05-01-2011, 08:40 PM
I recommend a 180amp esc and a Leopard 4082 1500kv. OSE also has some new motors worth looking at too that are in stock.
bbosncali
05-04-2011, 09:19 PM
Agreed 4082 1500kv is a beast of a motor...... it will give you more punch and still plenty of rpms.. jpriami hit 58mph with one just to show you how fast those things go. The motors your looking at are a much smaller can and only put out around 2200-2400 watts and a 4082 puts out 3500watts big difference
U1Racing
05-04-2011, 10:11 PM
i have many tacon motors in misc. rc things and have had no problems, i would say that the one in my losi mini-t out performs the C.C. that was in it previously and has already outlasted it for 1/6th or less the price at $11
bbosncali
05-04-2011, 10:23 PM
I have a tacon 4074 2000kv which I have yet to run in my mg. I'm going to try it out this weekend if it performs anywhere near what my 4074 leopard did then ill be very happy
Alexgar
05-04-2011, 11:10 PM
Also check out those keda motors here at ose there like 60-70$
JackBlack26
05-04-2011, 11:29 PM
If I had this boat I would go Tacon 1300kv on 6S, 2P and a T-180.
dag-nabit
05-05-2011, 12:28 AM
I'm starting out with Tacon 1700kv in my Spartans.
Haven't run them yet to give you an opinion on them though.
Kevin
the5
05-05-2011, 10:55 PM
Keda 1821kv or tacon 1700kv $54
$70 Keda 4074 motor
http://www.offshoreelectrics.com/pro...prod=keda-4074
dag-nabit
05-06-2011, 08:50 AM
$70 Keda 4074 motor
Good Question,
The 4074 would be nice because the 40mm can should provide better torque, but I don't know anything about these new Keda motors.
I haven't run my Tacon motors yet, but a google search reveals most people are getting good performance and reliability from them.
So the question is do you go with something new and relatively untested (I haven't found much info on them yet), or with something that has some history behind it.
They also could be great motors at a decent price??
Kevin
Brushless55
05-07-2011, 10:20 AM
$70 Keda 4074 motor
being these motors are close in power I would run the Tacon 1700kv motor and save a few bucks at the same time
biggest reason for me is the lower kv over the other
it will be plenty fast with the Tacon motor.. mid to upper 50's will be no issue for it :thumbup1:
bbosncali
05-07-2011, 02:43 PM
Great motor hit my best in my mg with a tacon 4074 2000kv on 6s and a x642 prop. But my run time was a little over 3 mins with 5300mah packs. Never hit over 105 degreed on either esc or motor did hit 119 at my battery connectors so I'm definetly drawing some serious amps but well worth it
http://i1094.photobucket.com/albums/i446/bbosncali78/2011-05-07132951.jpg
Shaun78
05-09-2011, 06:59 PM
Even motor temps were low....u can go up to mid 100's and b fine.....oh ya and the genesis is 63.7 mph. Beat u by .3 mph
