View Full Version : New Stiletto
racer66
04-29-2011, 06:31 AM
Gus, just boyght me a New Stiletto:banana:and ordered a DX3E radio. Bought two Pro Boat Nicad 5100mah packs just to get me going.
I plan on buying a few of the Hobby King batteries, what do you guys recommend? Also, what's a good prop to run?
Any recommendations I should do before I get it wet:bounce:
ron1950
04-29-2011, 10:43 AM
look under darin's stiletto race prep thread for prop etc...it seems to have all of your answers for ya.....i ran 2 5000ma 2 cells in mine but one 4 cell will work just as well ....i keep mine to 5k ma usually...oh ya,,,most hk batteries have the 5.5 conectors on them so beware of what you order......
racer66
05-01-2011, 12:59 PM
Thanks Ron. Thinking for props:
X642
Grim 40X52/3
Octura 440/3 back cut .030" pitched up slightly(Darin Jordan)
Next will be trying to get a Pro Boat programing card, everyone is BO. Then some LiPo batteries. Change connectors to 5.5 bullets.
Should I upgrade my flex cable, if so what size do I need? Need some Grim cable grease and hatch tape. Been reading up on this here.
racer66
05-01-2011, 07:58 PM
Just took the Steletto out of the box:banana: Wow it is super looking and the fit and finish is awesome:thumbup:
The Spectrum Marine rx that comes with the kit has two antennas. So, do I put the longer of the two in the antenna tube and the other coil up in the radio box:help:
Have my NiMH 5100's charging. The LHS will have my DX3E in this week. I can bind the rx to the tx and get the cables set up. Also set the drive unit to specs.
I will be ordering some LiPos and a prop. Gonna try to P/B/S my own prop:buttrock:as Chuck is weeks behind, I need one soon
bbill1
05-01-2011, 08:03 PM
Don't polish the prop. Take it from a nitro guy. Looks pretty but it is time wasted. An unpolished prop will be faster.
racer66
05-01-2011, 08:28 PM
Thanks!
gmkelm
05-02-2011, 10:14 PM
The longer antenna goes up the tube and you can coil the shorter one inside of the radio box. Be sure to reseal the radio box with waterproof tape.
Mark
CHIEFY_44
05-06-2011, 12:32 AM
i will suggest a prather 220 prop s/b then tune your boat to your style of driving, becareful they are tricky boats to get used to don't think ur gonna just go to the lake and drive it fast u will have to learn how to drive this boat, do not try to pih the throttle and expect it to corner at the same speed if try this i promise you will get frustrated with it as it will turn turtle or hook and spin out everytime, in the first 5 days i had mine 3 times i went out and ended upside down, take ur time learn the boat then try for max speed. As darin said to another person outta the box its more than fast enough for someone new into the hobby.
CHIEFY_44
05-06-2011, 12:48 AM
i have found that hyperformance products flex cables work great if u ring them and ask for the cable with the black stripe around it they will know what u want, while on the phone get one of his prop assemblies too
