View Full Version : anyone know anything about Trinity Brushed motors?
crrcboatz
04-24-2011, 08:43 PM
I have a couple of trinity sapphire 17 t motors and have no idea what they are. Got time in a grab bag of electric stuff. They are hooked to a tranny and they run duel hookup on it. I am not sure they have ever had a battery to them. Look new.
what is 17t? good bad neither?
should I just chunk them and replace with 380 brushless motors?
Can post pics if necessary
tiqueman
04-24-2011, 11:06 PM
I used to run Trinity motors in a lot of my touring and pan cars. Stock I belive was 23T (turn)... its been a while. So 17T is a little hotter motor. I liked my Trinity motors a lot.
Heres an article that mentions them for boating entry level racing
http://www.rumrunnerracing.com/articles/entry_level.htm
Is the sapphire a speed gems series? http://www.rc-truckncar-tuning.com/speedgems-extreme.html
crrcboatz
04-25-2011, 12:03 AM
Great info and tnks. So 2 of these in a tranny would work in say a small 18" or so boat? With 2 could I run a 7.2 lipo for power? What kind of speed controller would work too.
Alexgar
04-26-2011, 11:39 AM
i ran a trinity 14 t in a touring car and it was the first car i hade go over 35 mph i ran it on a novak explorer fo years and in my first bby ovalmaster 21 on a x431 6c nimh. the duratrax streak is a cheap (30$ new)12t capable esc and you could prob pick up a couple used ones for nothing
crrcboatz
04-26-2011, 11:49 AM
Ok the 2 motors are wired together, so can i use one esc say the duratrax as you suggested? Also, could I run 2s or 3s either one? I have a small 18" hull for this setup, ie the tranny that uses both of these and converts to 1 shaft and collet.
Alexgar
04-26-2011, 11:44 PM
Are they run in series cause 2 of those in parallel might be hard in a lower line esc
wparsons
05-08-2011, 10:32 AM
They won't spin as fast in series, but if you gear accordingly you should be fine.
I used to race my stadium truck with that exact motor. I would give the commutator a good cleaning and then some new brushes and they should be good to go!
crrcboatz
05-08-2011, 07:47 PM
Much appreciate your comments, knowledge and willingness to help my friend!! Will clean the commentators, and yes they are wired in series, ie, +&- from each hooked leaving one of each for the power.
Question, how much power aka volts should I use with them/
wparsons
05-08-2011, 09:04 PM
With them in series you can definitely run 4s lipo through it if your ESC can handle that.
crrcboatz
05-08-2011, 11:41 PM
Well I think it can, I planned to use a waterproof traxxas from a emaxx that had 2 550 titans.:help:
NativePaul
05-09-2011, 09:28 AM
I used to run a single trinity ruby 16 triple on a 2:1 ratio on 7 1700SCRC NiCads with X640 in an 18" cat giving 28mph. Upgraded to 400 size Mega 1615/3 10C3100mah 3s, X431 cut to 28mm for 36mph in the same hull with double the run time.
A dual gear drive is pretty heavy for an 18" hull normally we would be using them in 24-27" boats. I would take one out and use it as a single on 2s if you have the ESC already or if you don't go BL its not worth buying brushed stuff these days, you could probably get a cheap BL motor and ESC for similar price to a brushed ESC and get much better performance.
