View Full Version : newbie
kin
01-24-2008, 12:04 PM
:smile: hi guys im from singapore and just got hold of my first sv27 , yet to run it , still charging my batts , im on 5000mah 2s lipo`s and stell 40 mm prop, yet to check how fast she`s gonna run for me . any advice for a new boater from the experts??? everything alse is in stock condition
Doby
01-24-2008, 12:05 PM
Tape The Hatch:doh: :doh:
kin
01-24-2008, 12:24 PM
ditto~ will get those thin sized double sided tape than before i run her in waters ~
SweetAccord
01-24-2008, 01:55 PM
Guess depends on what you received as they are all a little differently assembled? Check the drive line (cable) that it's not binding, mine was more that what I felt was appropriate. After disconnecting the coupler and re-adjusting with different cable, now it's much much more free than initially received. You should not need to change the cable, but check for binding. Also, check all the screws on the back, some may not be screwed in all the way. Some of mine were not. Not that it should be bad, but maybe try the ESC and servo out to make sure it all is working before you go hit the water? Note: don't run the motor out of the water at full throttle if you plan to test that. Just checking the steering and it would not hurt if you have a volt meter check the motor output lines from the ESC they have voltage.
Hmmmm........what else? Can't think of anything more as yet.
H&MWill
01-24-2008, 02:21 PM
Remove hardware and silicone everything. Coat all wood inside with a light coat of epoxy.
Doby
01-24-2008, 03:05 PM
DO NOT USE DOUBLE SIDED TAPE TO SEAL THE HATCH:cursing: :cursing:
Use Hockey or electrical tape. I use Electrical tape and it has worked well, except in colder temperatures.
motoxbob11
01-24-2008, 08:30 PM
Do a pressure test on the cooling system. Mine was leaking through the threads of the brass outlets on the speed control. Sealed them with thread lock. Also move the antenna to a new mounting spot on the rear deck of the boat and seal up the original hole.
kck741
01-24-2008, 10:09 PM
Cut away stock battery location and put velcro on each side,it will help you find a good COG
kin
01-25-2008, 03:16 PM
thanks guys for all the advice given , appreciate it much~ i ran her today and boy or boy she was fast on stock set ups , my estimation speed is around 60+ km/h on lipos , she tend to bop alittle on the bow tho , but nevertheless it was just mind blowing to run her fast , motor was hot after a 7mins run , no major leaks tho , got her sealed up pretty well , got back and broke the the smaller wood that kept the batts from sliding and have moved the batt slightly infront than the normal location , hope the bow doesnt bop much with this CG position , and is a 3 blade grim racer brass prop be a good change from the sotck one ?
or any other suggestions on prop ? i`m loving my sv now , she sits right infront of me on my desk ,,,,,,
Dale Koblitz
01-26-2008, 02:35 PM
Octura x or m 442 or 642 are suppose to be just about right for the stock system.
kin
01-28-2008, 12:26 PM
from where i am the boating scene is small unlike for helis , so spares r limited , cant get octura unless bought online , only prather or grim racer, any advice on thos props ? and my bow tends to bop alot at high speed , any solutions?
Dale Koblitz
01-28-2008, 12:42 PM
I've heard the prather 220 works well on there. As far as the cavitation goes try putting the trim-tabs down a little or tucking the rudder up under the transom.
kin
01-29-2008, 07:44 AM
have moved forward the batt packs but still getting the bow hopping much , and have no idea how and which bolts to unscrew to adjust the rudder and strut settings , any suggestions n help be appreciated here , thanks in advance ~
Bill-SOCAL
01-29-2008, 09:26 AM
Try this:
http://aquacraftmodels.com/boats/aqub22-tuning.html
kin
got a idiot question to ask , does the stock esc has low voltage cut off?
kin
01-30-2008, 02:53 AM
Try this:
thanks bill~ im sticking to the stock condition set ups for now and move ard the batt packs for better cg and take it from there as for now
Dale Koblitz
01-30-2008, 03:07 AM
It does have a low volt cut off but I'm not sure what it's set at. I think I heard it was set just a little low to rely on it for 4s lipo's. Thats what I heard anyway. I wouldn't whant to chance it with a couple hundred dollars worth of lipo's. I'de get a 4s low volt cut-off like the ones Novak sells.
kin
01-30-2008, 06:26 AM
ok but im sure the lvc will work just fine as stock and as long we dun run it deep to hurt the lipos , thanks for the info... just had a run with her , SWWWEEEEEEEETT.
kin
02-01-2008, 12:20 PM
plan to run my sv in few hours time, have brought my rudder slightly to the stern in , hope to get her plane well with my new cg , hope all turns well for me very excited , 15 mins walk to my lake
cant wait
domwilson
02-01-2008, 12:23 PM
Post some videos and some speed readings. We love to see what you come up with.
kin
02-01-2008, 12:40 PM
would love to , but am gonna run it alone and no one ard to help me with the video tho , might just snap some pics on my on n post it tho. and as for speed readings , no gadget onboard yet to do speed readings just yet , :sorry:
plan to go full throttle this time , if all hells break loose and if she over turns , i got to get wet to retrive her lol
, lake has some daunting stories of snakes swimming across at times and huge monitor lizards too lol . dun wish to encounter those guys for now hahaha wish me luckkkkkkkkkkkkkkkkk
domwilson
02-01-2008, 12:53 PM
Good Luck and send us those pics.
kin
02-01-2008, 11:02 PM
had a sweet run with her and she planed well ,, sorry no pics or videos to post yet , was all alone enjoying my sv ~ kekekeke
kin
02-04-2008, 03:53 AM
realised after tucking in my rudder makes the boat very stable with gd CG but lost of speed tho , need more fine tuning next time she goes for a ride~
Dale Koblitz
02-04-2008, 11:46 AM
Yes, you need to find the sweet spot with stability and speed. You will sacrifice some speed to keep her planted but not a lot once she's set up just right. Don't forget you also have trim-tabs and a strut to adjust. But unless you have the adjustable trim tabs I reccomend taking them off to bend them and do it in very small increments. Remember a very small adjustment will make a big difference even on the strut and rudder angles. Even 1 degree makes a huge difference, also the water conditions have a big impact on performance
kin
02-04-2008, 12:38 PM
yup yup i agree~ gonna trim the rudder back alittle to get my speed back and gonna bend the trim plates down alittle more , keeping the strut more neutral .
kin
02-09-2008, 02:45 AM
hi guys ~ ran my sv today with the GR prop 40x52/3 sharpened . rudder was away from stern and CG was almost perfect for a good plane. but realised when i full throttle from start she takes almost 2 to 3 secs to get full power in , any idea why ? and my tubings r all clear of kinks and yet i see driplets than constant flow out the hull too . experts on sv r free to comment and advice ...
appreciate it ~
Dale Koblitz
02-10-2008, 12:24 AM
Do you mean to get on plane like cavitation or is there a electrical hesitation from the esc to motor when you pull the throttle? Are you running the stock system now? Have you taken the motor jacket off and checked to make sure all the holes are free from excess silicone? I had to cut a bunch of little pieces out of mine. Also is the drips while taking left turns and the stream on right and streight aways? Because of the rudder intake being on the right side and this being a race boat meant for right hand turns the pick-up works much better turning right. Oh, but have a seperate pick-up on the bottom of the transom don't you? I also board all the hose connectors out with a larger dia. drill bit along with my rudder pick-up? You can check each part seperately with a turkey baster by taking the tubes off and flushing water through each section to find the problem area!
kin
02-10-2008, 01:24 AM
cooling system solved , got water coming out smooth now , but i still dun get the punch when i full throttle till bout 2 -3 secs , it moves off slow than full power in . from stop to moving off in full throttle is what im refering to , when i fully throttle her , she takes some secs to get going .
Dale Koblitz
02-10-2008, 02:03 AM
Does it seem like it's cavitating or does it seem like a punch control type of setting on the esc?
kin
02-10-2008, 01:08 PM
ok i assume its cavitating , thanks for the enlightment .... dale
Dale Koblitz
02-10-2008, 03:46 PM
Well, then it's allmost certainly a prop issue!
kin
02-14-2008, 01:28 AM
ran her on a plastic 2 blade prop and was sweet enuf for me , poor vid tho , got some construction workers near by to help me shoot it from my cam phone .lol
http://www.youtube.com/watch?v=l5nEiAroBP4
domwilson
02-14-2008, 01:35 AM
What motor and prop were you using? She looks pretty fast!
Dale Koblitz
02-14-2008, 01:55 AM
Wow, must have got your ammo back huh? That's not stock unless that vid is edited by the looks of it. There's no cavitation anymore! 2 blade props usually jump out of the water quicker. Hops out a lot faster then that 3 blade grim prop I bet. Looks great that thing flys for a SV. So is it the ammo and the hydra 120? What size prop? You say it's carbun fiber or CF right or is it really plastic? Do you have a gps? I bet she's going 45mphish. Your running smc 2s lipo's right? Refresh my memory! What did you think of that tunnel I sent you the lnk for, The FE TS2 with SV power? That would be a pretty good deal for a trade streight up for an SV. I'de probably do it but I just got my SV for x-mas and haven't got to run it yet since it's been like 10 to 20 degrees -0 here ever since I got it allmost and all the water is solid.
kin
02-14-2008, 02:12 AM
to be very honest with u guys , theres no editing to the vid , im running a humble 5000mah 2s x2 , on a plastic 2 blade prop and the rest r all stock condition , not even a hydra 120 on my boat yet , prop size is 45 if not mistaken , too many props with me to play with , got a unknown brand and its cheap here , but after the run she was all hottttttttttttttttttttttttt , one of my lipo`s slightly bloated tho , but i enjoyed it much lol. 38 secs and 1 min 50 secs , she when fast at full throttle
from still , after that didnt push her much
kin
02-15-2008, 05:00 AM
my li po is blaoted after running her today, but its only one of the pack thats bloated, what can be the issue?
Dale Koblitz
02-15-2008, 12:26 PM
That one was jut the weaker pack so it gave up. Electric boats allways find the weak spot. What size prop are you running? How many runs aproximately are on those lipo's? I'm surprised the stock system would do that to a good lipo unless you were running to much prop on there. Maybe that is why your boat seemed to be going so good in the vidio.
kin
02-15-2008, 01:02 PM
im guessing its a 45 on props , got it from a no brand prop ,
my lipos r less than 12 cycles , does that means i cant use that pack anymore ??? its still boated after few hours .... sigh~ but nevertheless i was happy with the speed she gave me . hehehehe, she was stable too due to gd CG . now my local guys r asking if im gonna sell my sv ..... kekekekee,
Eodman
02-15-2008, 02:13 PM
Looks like you have an opportunity to make some money and build up some competion!
Apples1
02-15-2008, 06:53 PM
wouldn't use that bloated lipo unless you want see some smoke and flames lol, the manafacturer may replace it if it's only 12 cycles old. how much did you pay for the lipo's?
kin
02-15-2008, 07:03 PM
well i paid bout $180 sing dollars, now my boat be in the yard for awhile i guess .....
kin
02-25-2008, 11:10 PM
got a free replacement batt for free cuase it was less than 10 cycles , but im a little down becuase of the small boating community in where i live in and so the action is very limited or to even gather rc boaters down for a fun run .. and my sv is doing good with the speeds tho....
Dale Koblitz
02-25-2008, 11:31 PM
Maybe try a smaller prop to begin with when you get your new lipo and watch temps. Make sure there's no binding with the flex drive because if your puffing up a 5000hv 20c lipo your probably drawing 100 amps or better unless you just had a bad pack. Is the stuff tube alligned with the motor shaft? I would start with a 40 or 42mm prop because it will put less of a load on everything including the packs.
