View Full Version : Disconnecting the BEC
wppracing
04-23-2011, 06:07 AM
Going to run an RX battery pack and want need to know which wire to remove. I have seen pictures of the blue or red wire unplugged.
RayR
04-23-2011, 06:17 AM
Use a short servo extension and cut the middle (red) wire. Then no need to mess up your speedo plug.
wppracing
04-23-2011, 08:10 AM
Where are you removing the red wire from ? The ESC ?
A picture will help...
04-23-2011, 08:17 AM
He showed you a picture. You do not "remove" the red wire. Simply cut the red (middle) wire in the servo extension. Plug the modified servo extension between the ESC and the receiver. Voila.
H2OCamel
04-23-2011, 09:05 AM
I use the same method it saves you when you sell your equipment!
wppracing
04-23-2011, 09:23 AM
Got you now. I was stuck on the wires going to the motor
Diesel6401
04-23-2011, 10:32 AM
I never cut my wires. I just pull it back out of the esc itself. Use a small jeweler flat head and lift the small locking tab and slide the red wire out..... no extensions no ruining a esc takes 5 second. I just place a small piece of heatshrink over the exposed wire.
* I do like the extension idea though for quick switch between different setups.
wilsta67
04-23-2011, 04:52 PM
what does the bec do to start with and what advantages does it have by disconnecting it??
LiPo Power
04-23-2011, 07:44 PM
BEC is power to your receiver.
By disconnecting the power to receiver and using external power source like stand alone battery you will save the esc from failing....
Diesel6401
04-23-2011, 07:45 PM
Battery Eliminating Circuit..
Its in the esc, it takes the main battery voltage and reduces the voltage to provide power the rx and the servo. By removing/dis-abling it it ttakes added work/stress away from the esc increasing the life and durablilty of the esc. Most HV esc'c do not have bec. With added main battery voltage the harder the esc has to work to reduce the voltage for the servo and rx. Now this isn't the best answer or most technical by any means but you get the idea. I am sure Fluid may be able to provide a better idea on how this all works.
On most 2s-6s esc's such has the Hifei and Seaking (non-hv), I don't use the esc's bec on anything over 4s... That is just me, I also don't run those esc's past 5s. Once again just a me thing. I don't like pushing those to the limits. Not worth it to me...
Diesel6401
04-23-2011, 07:51 PM
Ooops, you posted while I was typing... lol
Didn't mean to repeat the similar answer.
wilsta67
04-24-2011, 02:01 AM
so if you just remove the center wire what are the other 2 wires for?
and where do you connect the external battery power too ? can you connect to any other port on the receiver?
Diesel6401
04-24-2011, 02:05 AM
Signal and ground...
Your rx should have a batt/bind or something similar slot That is where i run my rx pack. For the most part any slot will work though unless you have a telemetry rx.
wilsta67
04-24-2011, 02:08 AM
ok so is a 6volt nimh hump pack battery ok for the power supply?
pyroM!KE
04-24-2011, 02:22 AM
Yup..Its what I use.. http://www.gshobby.com/index.php?main_page=product_info&cPath=737_1188&products_id=11131
wppracing
04-24-2011, 05:00 AM
I just removed the red wire from the connector and put a small heat shrink on it and taped it to the rest of the wires. Comes out of the connector real easy. A small 5hump battery pack fits nicely also.
Diesel6401
04-24-2011, 11:51 AM
Yup would work just fine bud.
