View Full Version : New steering servo needed
trevorla
04-22-2011, 11:59 AM
Anyone upgrade their steering servo? I think my traxxas 2056 is shot.Took it apart it smells funny and was warm to the touch.It appears to be not as waterproof as advertised...
wilsta67
04-22-2011, 04:23 PM
any std size servo will fit.
04-22-2011, 05:04 PM
But why put just any servo in the boat? A boat that size needs a high torque servo to keep good control at high speeds. The force on the rudder can overwhelm a standard servo, causing funky control in corners, hooking, etc.
A servo with at least 80 oz-in at the receiver voltage supplied is a minimum IMO. The first below should work if you have 6 volts to the receiver. If you only have 4.8 volts to the receiver, then use the second one, which is the better choice either way.
http://www.servocity.com/html/hs-485hb_servo.html
http://www.servocity.com/html/hs-645mg_ultra_torque.html
Brushless55
04-22-2011, 05:06 PM
Hitec HS-645MG is good and cheap!
http://www3.towerhobbies.com/cgi-bin/wti0001p?&P=SM&I=LXUZ89
wilsta67
04-22-2011, 05:07 PM
thats a std size servo lol
a micro servo will be to small and a 1/4 scale to big 0_o
Brushless55
04-22-2011, 05:15 PM
Uhhhh :confused2:
fluid and I both posted std size
roadrashracing
04-22-2011, 06:40 PM
Mine went after 4 packs, I send it in and I'm getting a new one
Brushless55
04-22-2011, 06:50 PM
get the HS645MG you will like it so much more:Peace_Sign:
