View Full Version : Small Bolt Drive Shaft Problem Advice Needed
CaptPJB
04-17-2011, 03:32 PM
The flex shaft on my Small Bolt unraveled probably due to pressure from the set screw over time would be my guess.
So do I just replace the flex shaft and if so where can I get one with the square end also can you just get the flex end or does the two piece unit come as a set?
Or would it be better to upgrade to a single piece flex drive which would make greasing so much easier and if so what what do I need to convert and where to get it?
Thanks in advance
Peter
monojeff
04-17-2011, 03:39 PM
Try this out http://www.offshoreelectrics.com/proddetail.php?prod=oct-oc098L-24c
monojeff
04-17-2011, 03:41 PM
Basstronics has couplers he is selling to work with stock engine.
http://forums.offshoreelectrics.com/showthread.php?t=23790
Basstronics
04-17-2011, 03:44 PM
I have only 2 couplers available right now. One for the stock motor and one for the Tacon motor.
Moving to .098" cable setup was a smart move for me!
monojeff
04-17-2011, 03:54 PM
I sent you a PM on the tacon coupler did you ever get it??
CaptPJB
04-17-2011, 08:41 PM
Moving to the .098 cable I am assuming I would I need a new coupler for the stock motor like Basstronics sells as well as this http://www.offshoreelectrics.com/pro...oct-oc098L-24c?
Peter
wparsons
04-17-2011, 09:15 PM
You could also contact Jeff Wohlt to get a wire drive made for it. I'm planning on making my own wire drive if I keep mine for this summer, but might be selling it to free up space for a new build.
SweetAccord
04-17-2011, 10:48 PM
Use the Etti coupler one OSE which is better than any set screw coupler. This is what I'm using. If you mod it you can make it easily fit the .098 flex cable tightly and no more damaging set screws into the flexdrive and it will hold evenly not in one or two places like a set screw coupler. Steve has these here as I asked him to get these for me for all my 2040 motors and he has more left.
SweetAccord
04-17-2011, 10:55 PM
This is what I'm using also works great. Get rid of the bushing in the strut. Search the RC Universe thread for Mini Bolt and you will find my post on the bearing mod. It's easy and works extremely well.
Basstronics
04-18-2011, 05:56 AM
The Etti coupler fits?
I know there is a length and diameter limitation- not much room.
I had Jeff make me a .062" wire drive and a special coupler. The wire is just to big for the bend at least on my Bolt. The drive/coupler is in the FS section if anyone wants to give it a try.
wparsons
04-18-2011, 07:51 AM
Octura makes a collet for a .098 cable as well, but the motor end is 1/8" (540 car motors), you can cut a short length of brass or aluminum tubing to sleeve the motor shaft and it will work just fine. Just notch through the tubing so the set screw goes right to the motor shaft, not just the tubing.
CaptPJB
04-18-2011, 08:40 AM
Since I have been known to buy the wrong sized coupler in the past :) can you give me the product ID for the OSE coupler please? I assume that the OSE .096 flex means I need to mod the strut housing bearing as well? I will search RC Universe as you suggest for how to etc.
Reasonably new at boats so apologize if some of this is obvious to more seasoned FE boaters!
Thanks
Peter
wparsons
04-18-2011, 09:32 AM
If you get a 1/8" stub shaft you should be fine with the strut as it is stock. You could run a smaller diameter teflon liner with the smaller flex, but don't have to.
CaptPJB
04-18-2011, 10:51 AM
Thanks for the info no strut mods needed.. Regarding using a Octura collet and a sleeve I would prefer not to do that if an Etti will fit.
Peter
CaptPJB
04-18-2011, 01:28 PM
Is this the one and you enlarge the 2mm end to 2.3mm or there abouts for the .098 flex?
Product ID: etti-a006
Etti Coupler 3.175 to 2mm
In Stock: 8
Basstronics
04-18-2011, 06:39 PM
Measure twice.
The stock motor is not the 2.3mm it advertises to be!
At least not mine. Another person confirmed theirs is 2.2mm as well.
SweetAccord
04-18-2011, 07:20 PM
Wparsons is correct and that was my first mod. when I was into removing the drive line and greasing (now I use oil). I changed as it was just big and heavy and ran close to the hull but worked like a charm. You can see my old pic in my album that was in my Starship (I need to update, LOL).
On Amazon you can get stainless steel tubes to make that coupler work as that is what I did, for the motor side and use loctite on it and you are good forever and the stainless steel tube when hit with a allen screw holds well. In searching for something smaller and lighter the Etti was just right for me. You can make it work too. :smile:
SweetAccord
04-18-2011, 07:21 PM
In Stock: 8
Yes that is it! It's not a direct fit for the stock motor as I'm not using it. I'm using these on Tacon motors and it's a direct fit on them. I measured, on the stock motor you need to bore it out one side to fit the motor shaft, the other side you can cut a 1/8 copper tube (slit it so from one side to the other so it can compress) and slide that tube into the other side and the flex cable will go into that and it will compress when tightened down but you have to make it fit but it holds tight! I did this so it's small and has less rotational mass than anything else and is lighter and can be removed easily and no flex drive damage from the screws. If need to remove the drive line ( I don't ever) then I can and the flex cable is not grubbed in. What does Jeff Wohlt now have? I asked him long ago and he said he don't do anything this small.
SweetAccord
04-18-2011, 07:51 PM
Measure twice.
Mine is 2.27 mm, that is right. By the way I'm "Research" on RC Universe. I may be the "other guy". :laugh:
CaptPJB
04-18-2011, 08:05 PM
Yes that is it! It's not a direct fit. I'm using these on Tacon motors and it's a direct fit. On the stock motor you need to bore it out 1mm one side to fit the motor shaft, the other side you can cut a 1/8 copper tube (slit it so it from one side to the other so it can compress) and slide that tube into the other side and the flex cable will go into that and it will compress when tightened down but you have to make it fit but it holds tight! I did this so it's small and has less rotational mass than anything else and is lighter and can be removed easily and no flex drive damage from the screws. If need to remove the drive line ( I don't ever) then I can and the flex cable is not grubbed in. What does Jeff Wohlt now have? I asked him long ago and he said he don't do anything this small.
Thanks for the explanation on how to make the Etti work
Peter
SweetAccord
04-18-2011, 08:23 PM
Peter
No problem. But see what Jeff can make if he can as a custom direct fit is best, let us know. I spent months looking and there is just nothing else that comes close but the Etti when modded.
SweetAccord
04-18-2011, 08:52 PM
I also forgot to mention. If you go to the .098 cable, and you want an identical motor coupler, the one from Minicat racing works. I have them (spares from boats) and tried it on the stock Bolt motor and it's fine.
SweetAccord
04-18-2011, 09:08 PM
The biggest change to make on this boat including the drive, is to replace the busing in the strut and use a bearing. That works wonders!
Basstronics
04-19-2011, 05:57 AM
Is that measured with a caliper or a micrometer?
I measured mine with a micrometer w/friction thimble and mine is 2.2 mm. Not 2.3mm. Not 2.2X mm- it is 2.2mm exactly.
I sent Jeff a print for these couplers and he didnt seem interested in making them or it was going to be some time until they got made.
There is nothing ground breaking about them. 3/8" Dia x 7/8" lg. Motor end is drilled 3/8" lg and flex 1/2" lg. Add set screws.
SweetAccord
04-19-2011, 10:38 AM
It's cool bass. I measured with a digital caliper which is accurate as I have other projects with factory spec values and my caliper matches exactly to their values. For example I have different motors with screw spacing that is factory spec of 16mm and my caliper is exactly on that value. It's accurate to 0.001 mm. A micrometer would be more accurate but the difference in tolerance of 0.07 between 2.27 and 2.2 is so small there is no effect. Human hair is 0.05-0.06mm so you can't even see or feel the difference. So we are literally "splitting hairs". :laugh:
Also on these motors I would not look past that the shafts are all off in size so a difference of 0.01-0.07 is not surprising as these are not high quality motors and mass produced. If you look at the shaft, it does not even looked milled down very well compared to others I have so I don't feel your measurements are off nor mine.
Basstronics
04-19-2011, 01:08 PM
Im going to disagree here on multiple basis's.
I cant comment on your background but let me share some of mine. I was a Machinist (trade school trained) now turned Design Engineer. I have run a variety of machines and have worked on more materials than a human being can remember... I have done many bearing journals down to .0002" micrometer and dial bore gauge as well as a bench micrometer on tungsten laser rods down to .0001" with a scope for porosity. I have also received a certificate thru Federal Mahr on fine surfaces.
A caliper is in no way even remotely accurate to .001mm. A caliper is known to be accurate to around +/- .001". You can easily see that variance depending on pressure applied and where you measure on the jaw. That is why micrometers with a friction thimble provide the most accurate readings.
Claiming you have compared caliper readings for bolt spacing to the stock spec is irrelevant. Tolerances and machine inaccuracies can void that out as qualifying as an accurate basis for true measurement. Furthermore compounding that is how it was measured?
.07mm is enough difference- its a huge difference. These boats and spaces are tight enough that every little bit counts. Between my coupler to my brass stuffing tube/teflon theres about 1/8". Now if Im .003" off in my coupler, when you wrench down on the screws it will throw the concentric off balance. This will make wobble on the flex end. The bottom line is the more you are off on the motor end the greater the wobble will be on the flex end.
The best coupler is one size to size or a collet type as far as run out goes.
The smaller the sizes and distances the more critical the tolerances becomes.
its design 101.
I would highly advise anyone with these motors to measure with a micrometer to ensure you have an accurate coupling.
And just for poop and grins:
2.2mm = .0866"
2.27mm = .0894" (+.0028")
2.3mm = .0906" (+.004")
Basstronics
04-19-2011, 01:14 PM
Oh and last part...
I have a different motor with a true 2.3mm shaft (as verified by micrometer) and a coupler for that motor (airplane prop). You can see a big difference in wobble when placed on the small bolt motor.
SweetAccord
04-19-2011, 01:49 PM
My caliper is mm not inches. Inches is a horrible way to measure anything it's is not precise enough. But if you want to go into .07 mm of a difference go ahead. I have to laugh.
Basstronics
04-19-2011, 02:13 PM
Measurement is a measurement. I can convert it multiple of times and not loose anything many places out.
In my job we work mainly in inches and its not uncommon for me to scale things from metric to inches- which is a factor of .039370078740157 and thats by memory.
The part that you miss is the run out due to excessive clearance. When you amplify the clearance over the length it will produce a wobble.
Laugh as you will. I aim for perfection.
Basstronics
04-19-2011, 02:25 PM
Its beyond .07mm thats whats your not getting.
I dont expect you to understand this as obviously you are not a machinist accustomed to such issues or an engineer who envisions such instances.
While it may not affect it that much it will have a negative effect to some degree. When you compound that with a wobble in the flex with not much free room for the flex it will amplify the issue more.
The principles of this is fairly simple.
