View Full Version : What am I not doing correctly?
Havasufun
04-17-2011, 11:52 AM
So...my maiden voyage was last night and early this morning...running 6s with 180seaking and stock motor...seems like its missing some power...do i need to disable the BEC on the 180esc or any other tweaks like that?
PDR447
04-17-2011, 12:05 PM
if it was your maiden how do you know it is missing power? you have nothing to compare it to...
jac4412
04-17-2011, 12:09 PM
what prop are you using
I would disable the bec. Also check the timing, the seeking comes factory 15*degrees. I'm not sure what the stock motor requires
Havasufun
04-17-2011, 12:34 PM
x642 prop...polished and balanced
How do I go about disabling BEC? Do i have to run an rx pack if I disable...What does disabling do?
Timing is 15
Thanks
JackBlack26
04-17-2011, 01:05 PM
Pull the red wire from the ESC connector and heat shrink it back. Use ether an external BEC or a receiver pack. Disabling it puts less stress on internal circuitry, making the ESC run more consistent, specially on 6S.
Havasufun
04-17-2011, 01:17 PM
I have a castle CC BEC rx battery eliminator...that will work?
bbosncali
05-01-2011, 08:31 AM
Yep sure will
