View Full Version : Programming Seaking ESC?
Shaun78
04-14-2011, 04:46 PM
I am running 6S. Should i use auto detect or set #3 says 3cells (6 cells) Does that mean 3 or 6 cells?
i will probably do 3.4 low voltage and 15degree timing and forward only just in case i need it....
BEC disconnected u still need to plug in power pack and lipos to ESC?
Diesel6401
04-14-2011, 05:30 PM
Don't use auto. Manully program. The first number is for LV esc's i.e the 120/180 the (x) number is for the HV esc's. i.e 80amp HV. What exact seaking do you have?
So setting 3 is:
3s on the 120 & 180
6s on the 80HV
* Timing depends on which motor you are running. 15 is great on a y wind, but may heat things up on a d wind. Which motor you running?
* Yes if the bec is dis-abled you need to still plug in your lipos and you will need a rx pack.
Shaun78
04-14-2011, 07:19 PM
I have the Seaking 180 with Leopard 4082 1500Kv. Running 6S lipos.
Setting 1 is 2 forward and reverse(i will only use if needed)
Setting 2 is #3 for 6S
Setting 3 is #5 3.4V/cell or maybe #4 3.2V cell
Setting 4 is # 5 15 degree timing
Diesel6401
04-14-2011, 07:36 PM
Dump the reverse.
# 3 on a 180 is not 6s it's 3s. You need to change to setting # 6 on the 180 for 6s. The 180 is not a HV esc, there for the number in () is not applicapable to that esc.
I run 3.2v per myself.
15* is good for that motor, its a y wind
Shaun78
04-14-2011, 08:01 PM
Ok, #6 says 6cell (12 cell). That's what setting I want to run 6s?
Diesel6401
04-14-2011, 08:02 PM
Yup, ignore the the number in the () is does not pretain to you!
Shaun78
04-14-2011, 08:31 PM
Got it,thanks
