View Full Version : 5.5 Bullet parallel conectors
egneg
04-10-2011, 08:01 PM
Picture how to ... any questions - just ask.
millzee
04-10-2011, 08:45 PM
Great stuff, I think I might have to borrow that idea, that'll help me shorten things up.:thumbup:
ron1950
04-10-2011, 10:04 PM
egneg u selling these things now with every prop?
tanasit
06-14-2011, 06:06 PM
Smaller banana plugs will do if you don't have the brass rod.
Superdave
06-21-2011, 01:25 AM
Can you post some pics of how these look in your boat. I still can't picture how they are set up?
Joe007
06-22-2011, 05:10 PM
Do you drill a hole through your connectors? My bullet connectors only have one hole in them...
Joe
egneg
06-22-2011, 08:15 PM
You can ... but the CC connectors I use have 2 holes and no cutout section.
egneg
06-22-2011, 08:19 PM
This is about the only picture I have at the moment - hope it helps.
53911
Basstronics
06-23-2011, 08:20 AM
I just bought some Castle 5.5's at the LHS and they dont have the thru hole :( Just curious if you have a part # for the Castles you get?
ksm2001
06-23-2011, 09:01 AM
Do the Castle 5.5's have a hole on one side? I made a parallel connector using Castle 6.5's and they only have one hole so had to drill out the other side to fit the brass tubing through which worked well .
Ken
Basstronics
06-23-2011, 03:40 PM
Yup just one side.
egneg
06-23-2011, 07:22 PM
I will have to double check ... as CC bullets used to be the only ones I bought.
Superdave
06-23-2011, 07:24 PM
53911
Cool is that just shrik wrap used to insulate the connectors? What are the little yellow rings?
Joe007
06-23-2011, 10:01 PM
egneg that picture of your set up is all I needed to get mine done...
Thanks,
Joe
egneg
06-24-2011, 02:24 AM
Yellow shrink under the black shrink
MarkF
06-25-2011, 08:36 AM
Thats a very good Idea. The only thing I would change is to use copper tubbing instead of the brass since it conducts electricity a little better.
Mark
FloatDaBoat
06-30-2011, 06:25 PM
Mark
A WHOLE LOT better !!!
egneg
06-30-2011, 07:10 PM
Mark
No need to over-engineer this as the brass works just fine without any heat due to resistance.
properchopper
07-02-2011, 11:51 AM
5468554686Chuck, a big thanks for this idea :Peace_Sign:
Some 8's I made for a customer :
egneg
07-02-2011, 03:41 PM
Actually Steven V did it first, all I did was add pictures in a step by step format. Before this I used 8 awg stranded wire but this is much easier.
Joe007
07-05-2011, 04:22 PM
Thanks for all the help here on making the double connection out of the bullet connectors... I went on line and on ebay found Tough Racing out of Seoul Korea, they have the 5.5 bullets with holes though both ends.... I got ten pairs with shrink wrap tubing for like $8.00 shipped to my house... Took less than two weeks to get them...
Basstronics
07-11-2012, 10:14 PM
Heres a new twist...
HobbyKing 8mm bullets. .155 solid brass rod- right thru the stock holes!
I made mine to fit the batteries. So I have 2 males/1 female, 2 females/1 male
http://i38.photobucket.com/albums/e136/basstronics/RC%20Boats/100_1179.jpg
http://i38.photobucket.com/albums/e136/basstronics/RC%20Boats/100_1180.jpg
http://i38.photobucket.com/albums/e136/basstronics/RC%20Boats/100_1182.jpg
Serpents811
07-11-2012, 10:35 PM
i made a set with cc 6.5 bullets but still havent found heat shrink big enough , help here with that
ron1950
07-11-2012, 11:09 PM
if your heat shrink is close to the size but not quit the right size streatch it with a pair of needle nose plyers...heat will bring it back to size
