View Full Version : M445 balanced prop on stock set up
wppracing
04-07-2011, 08:10 PM
Will a balanced M445 prop work ok with the stock set up? I run 7.4 40c and 50c lipos. and what timing should the esc be set at high or low ?
Diesel6401
04-07-2011, 08:21 PM
Prop will work fine. Set motor timing to high, get the rid of the deans connectors (if you haven't done so yet) and change out the 3.5mm bullets to 5.5mm bullets and you will have yourself a very nice running MG.
pyroM!KE
04-07-2011, 09:23 PM
On 4 cell not 5 cell...Dont do it on 5s..Ask me why..:flame42: :doh::crying:
Now, m445,stock motor, SK180 esc is awesome on 5s!!! Also a cf45 prop with the same setup is awesome 2..A cf45 on 5s will launch out of the water and ride a wheely setup just right..I love mine!! Only about 1 inch of the rudder and the prop only is in the water..
ron1950
04-07-2011, 09:29 PM
id try a 120a esc before id try the m445 on it....watch the temps really close
Diesel6401
04-07-2011, 09:35 PM
HAHAHAHAHAHAHAhA,
:rofl:
He posted he was running 7.4's so he's safe on 4s.... Yes to the OP that prop on 5s stock is no no.... Pyro has the charcoaled souvenir to prove it lol...
Diesel6401
04-07-2011, 09:36 PM
Stock system will handle that prop on 4s. As long as he changes the deans/3.5mm he should be just fine.
wppracing
04-07-2011, 10:10 PM
will it still work if I dont change the deans yet ?
LiPo Power
04-08-2011, 12:05 AM
Change the cheep deans to 5.5, please.....
fallensk8man89
04-08-2011, 01:18 AM
what all do you gain switching from deans to 5.5?
wppracing
04-08-2011, 06:00 AM
I wont have time to get the 5.5 bullets for this weekend. SO will leaving on the deans for some prop testing cause any issues with the stock set up ?
ron1950
04-08-2011, 07:06 AM
5.5's offer lesss restance so they stay cooler
bbosncali
04-08-2011, 08:59 AM
you'll be saving yourself alot of money in the end.. for about $20 in connectore vs $60 motor $70 esc $30-$75 x2 batteries = alot more than $20
start with something small like an x642 if you just can't wait but the bigger the prop the bigger the load and deans are only rated at 60amps on a good day
bbosncali
04-08-2011, 09:03 AM
ec5 connectors are another good choice and most hobby shops carry them. i use those on my esc and batteries and 5.5mm on my motor
wppracing
04-08-2011, 09:05 AM
Going to try to get some today and change all of them over. If not I will take off the prop and test it next week.
Diesel6401
04-08-2011, 10:51 AM
I wouldn't test a m445 with those deans or the 3.5mm bullets. The amp load is going cause issues for those items. Deans have NO place in FE boating, they are just the RC industry standard at this time.
Switching over is gonna add reliability to the setup. One of the best quickest and cheapest upgrade you can make to any RTR boat not just the MG is switching to bigger connectors and dumping the deans.
tiqueman
04-08-2011, 12:01 PM
Personally I would NOT run an M445 with the stock 45A esc. To me its a matter of when it blows up, not if. I swithed to a T-120 and after a 4min heat race, shes even a bit warm. And definitley go w/ 5.5s, no question about that. Deans will absolutely melt.
Diesel6401
04-08-2011, 12:10 PM
Very interesting.
I didn't have any problems with the stocker. Even though its rated at 45amps I think you would shocked on what it can safely handle. I logged 70amp spikes and 60amps constant on the stock esc with a pb1800 kv motor. Currently I'm running a cc 1800 outrunner with a 42x55 without any issues. That esc is far from a 45amp esc lol. So far I have been running the stock esc since the boat was released and this is the 3rd motor I've had on it. She's pretty tough lol.
tiqueman
04-08-2011, 12:44 PM
Ive seen 2 blow personally in front of me running M445s on the stock esc. I think some just get lucky, just like the 5 and 6S battels when the BJ26 was popular. I blew a stock esc back then running 5S, external bec etc etc, took all the precautions and it went up on run 3 running a x442. My thoughts are, if theres a chance, Im not taking it. Money for me anyway doesnt grow on trees anymore. Just my $.02 cause its all I can afford. Im also not one who like to tell someone "oh yeah, itll be fine", then when it goes poof, theyre all upset. Im just overcautious thats all. :biggrin:
Diesel6401
04-08-2011, 12:53 PM
O I hear yea cautious is def the way.I tend to right on the side of caution a lot myself.
wppracing
04-08-2011, 02:56 PM
I have some 5.5 bullets coming on Tuesday. Then changing all the deans connectors .
wppracing
04-10-2011, 05:07 PM
Ran the M445 today and it ran great. The boat didnt bounce at speed and had zero prop spin at take off. The esc and motor were cold to the touch after 10 minutes of running. Still going to change all the connectors though.
LiPo Power
04-10-2011, 08:36 PM
T-120 and M445 = NO PROBLEM...
wppracing
04-10-2011, 08:43 PM
Ran the prop again and did some temp readings.
Before running the temps were
Motor 65.1 / Esc 64.8
Did 6 high speed runs
Motor 79.7 / Esc 73.1
Did 4 more high speed runs
Motor 82.6 / Esc 75.4
Did approx 10min tight turns, short on/off throttle, figure 8s and oval, keeping motor under a load
Motor 84.2 / Esc 76.8
tiqueman
04-10-2011, 08:57 PM
Thats very good. Whats the water temp? After a heat race today my motor running a M445 and a T-120, motor was 121, esc was 118 at hottest location, 4S2P at 91F, running 5.5s everywhere. Water temp low 70s
wppracing
04-10-2011, 09:00 PM
Thats the only thing I didnt check. I would guess mid 50 to 60. I know the temps will increase once the water gets warmer.
gek1946
08-30-2012, 02:23 PM
On a stock Motley Crew how do you adjust the motor timing?
Also i have a Turnigy 180a from a pro boat. Should i install this in the Motley?
Is there any difference between a M445 and a 42x55 grim racer?
Thanks
