View Full Version : Spartan Shaft Size?
04-05-2011, 01:40 PM
Does anyone have any good measurements on the Traxxas Shaft? Reason I ask is I have a customer that lost his and traxxas is out of stock. I want to make some replacements.
I need the following?
Shaft diameter?
Shaft length?
Cable thickness?
Cable length?
Length(total) from End of Cable to tip of prop shaft?
JPriami
04-05-2011, 01:58 PM
I've posted it in here. Ill find them and post.
JPriami
04-05-2011, 02:00 PM
Total length of flex and stub shaft all together 15 ¼”
Length from end (where collet goes) of the flex to start of the stub is 11 ½” And the flex is .150 diameter
Stub is 3 ¾” long total
From where the flex goes in & stub begins the shaft diameter of the stub is .195 for a length 2.60” then it recesses down to .187 diameter for a length of .700” then the rest is threads for .400”.
Also the end of the flex where the collet goes is soldered.
does that help?
They have an oddball prop shaft size the goes through the strut bushing. it sucks
Brushless55
04-05-2011, 02:05 PM
would be good to offer a new strut to go with the new shaft?
dag-nabit
04-05-2011, 02:15 PM
Shaft diameter?
Shaft length?
Cable thickness?
Cable length?
If you build them, they will come. Especially if they are upgraded flex cable.
You can count me in for two.
Brushless makes a good point.
Because of the odd ball sizing on the prop shaft, another option to consider is offering a new 3/16" strut assembly that will bolt on without modifications (easy for the less experienced), then any upgraded flex shaft that is long enough and with standard 3/16" prop shaft could be used.
Also, the quality of the Teflon liner is suspect. Could be a dollar to made on good quality stuffing tube liners as well.
Kevin
GeoVW72
04-05-2011, 02:23 PM
https://lh4.googleusercontent.com/_nneVYSYZjrY/TZtbOUgnc6I/AAAAAAAAAfM/ihVNR8atrzU/s640/IMG_20110405_140908.jpg
Just illustrating to concur with JPriami
My guess is that the stub is 5mm to allow the use of standard ball bearings for the strut that has never materialized.
dag-nabit
04-05-2011, 02:56 PM
Very possible, .195" is 4.953mm
Kevin
Jeff Wohlt
04-05-2011, 05:35 PM
I have had several want to put wire drives in. I have the stock to do it as well.
tomjr
04-06-2011, 07:37 AM
Please have the flex cable upgraded for the spartan...
There is quite a number of guys playing the spartan here in singapore...
I am sure the respond will be great...
Jeff Wohlt
04-06-2011, 02:47 PM
Is that step down for 3/16" props or 4mm props?
JPriami
04-06-2011, 03:18 PM
It's for 3/16 props Jeff.
Jeff Wohlt
04-06-2011, 03:53 PM
Cool... nice they run a 5mm shaft. It would also be easy to do 187 cables.
Revo09
04-07-2011, 02:07 AM
If this happens i want two for me.
tomjr
04-07-2011, 02:34 AM
I want 3 if its the upgraded shaft
Jeff Wohlt
04-07-2011, 08:58 AM
Does anyone mind grinding their own flat for the dog? Should 187 cable be an option or is 150 enough?
JPriami
04-07-2011, 09:15 AM
.187 option might be nice for those running upgraded setups with larger props. As long as the stock stuffing tube isn't a problem. I put a .187 aeromarine cable in mine and it felt ok dry spinning.
Might need a new collet for the .187 cable? I didn't test fit that. Wouldn't be a bad idea to get a better collet anyways. The stock one is pretty light duty.
mavdriver
04-07-2011, 10:25 AM
.187 would be good LMK when they are available ? I`m going to try CC 1717 on my Spartan . :popcorn2:
Jeff Wohlt
04-12-2011, 11:43 AM
These are ready to go...just got the 5mm stock. I did not see them on OSE yet but I am sure he is getting some made. These will be brazed like the Hughey shafts. 150 and 187 size. They are factory specs.
mavdriver
04-12-2011, 11:51 AM
Jeff does the 187 size fit in the stock stuffing tube , strut ?
dag-nabit
04-12-2011, 11:53 AM
Just scooped 2 of them.
Kevin
mavdriver
04-12-2011, 11:54 AM
Kevin
what size ?
dag-nabit
04-12-2011, 12:00 PM
what size ?
I went with the .150 to match stock size.
Kevin
tomjr
04-12-2011, 12:01 PM
Is the spartan upgraded cable ready ?
Did not see it at the ose web shop.
mavdriver
04-12-2011, 12:02 PM
I`m curios if the 187 would work :confused2:
dag-nabit
04-12-2011, 12:04 PM
OSE doesn't have them yet, Jeff does.
Click the rcraceboat.com link in his signature line.
Kevin
dag-nabit
04-12-2011, 12:08 PM
Not sure. The .187 shaft is nearly 1mm larger diameter. I think you would need to either remove the teflon liner, or replace the stuffing tube and liner with a larger diameter setup.
This is just a guess, but it is why I went with stock sizing. I'm thinking a better quality cable should do the trick without going larger.
But I'm not looking to run extreme prop sizes and try to break speed records.
Kevin
mavdriver
04-12-2011, 12:11 PM
Kevin will do the same then thanks .
Ed
tomjr
04-12-2011, 12:23 PM
Kevin
Hi Kevin,
Will the upgraded shaft solve the shaft overheating problem ?
The reason why the shaft overheat is due to the traxxas crap quality shaft ?
I have the same problem...should we go bigger on the flex shaft or remain the same ??
dag-nabit
04-12-2011, 12:44 PM
Hi Kevin,
I really don't have the experience to answer that question.
I don't know that anyone knows for certain what is causing some spartan stuffing tubes to heat up, but I think the general theory is that the shaft is low quality and is "corkscrewing" inside the stuffing tube causing friction.
A high quality flex shaft should minimize the corkscrew effect, so I'm banking on a good quality flex shaft working for my setup.
I'm guessing Jeff is offering the larger flex shaft size for fellows like JPriami (or Brushless55 if he ever drops that CC1717 into his Spartan, hint hint, poke poke) that plan to push the hull to it's limits by running large, hi torque motors, and large props.
Those setups will place extra demand on the drive line.
Hopefully some of the more experienced boaters will drop in and give us the straight goods.
Kevin
EDIT: and keep in mind, if you go to the larger cable size, you will need to replace your collet as well.
tomjr
04-12-2011, 12:47 PM
Ok.. Actually worth the try... But if use the .187 I don't think can use the Teflon inner liner...
dag-nabit
04-12-2011, 12:52 PM
In case you missed my EDIT. Be sure to order a new collet at the same time.
Kevin
Jeff Wohlt
04-12-2011, 01:45 PM
If it were me and running any bigger power like 6S I WOULD remove the teflon and use a good marine grease on the cable and stub...I also like to grease and then put a few drops of regular 3n1 oil down them and the stub...makes it very slick. Not sure if OSEs are loctite or brazed versions but thought I would just go brazed since most want to run bigger motors and 6S. Yes, they are more time since they step and have to be threaded.
tomjr
04-12-2011, 07:58 PM
Hi jeff,
What do you mean by brazed ?
Do you have the brazed flex shaft for the .187 ?
Tom
Jeff Wohlt
04-12-2011, 11:21 PM
Brazed is just that...not soldered. 30,000 psi tensil strength. 1200 degrees with a brazing rod. It is 56% silver that I use.
http://en.wikipedia.org/wiki/Brazing#Silver_brazing
