View Full Version : need your opinion 2200kv or 2000?
gibbies_03
04-04-2011, 09:02 PM
I am torn on buying the 2000kv leopard combo with the 180A esc, or if I should buy separately and buy the 2200kv and 180A esc...
Is it really going to make a big difference? I am going to run 4S but on occassion run 6S for speed runs
thanks guys
bbosncali
04-04-2011, 09:20 PM
Like I was told that's way to many rpms... at 2000kv x 22.2 = 44400 rpms and 2200kv = 48400 rpms as aposed to 14.8 = 32560 for the 2200kv and 18.5vlts =40700 rpms
04-04-2011, 09:40 PM
There is no single motor which will give high performance on both 4S and 6S. The voltage spread is too much. Even on 4S the 2200 Kv motor is marginal in a cat if you want much run time. On 6S both motors are too much. Decide if you want to run 4S or 6S and get the appropriate motor...or get two, one for 4S and one for 6S.
ron1950
04-04-2011, 09:46 PM
the 2200 will run great on 4s
gibbies_03
04-04-2011, 10:18 PM
so what kind of run times can i expect to get out of a 5000mah 4S setup on the 2200 kv? Kinda just playing around recreationally...but ofcourse haulin so a$$ in between
bbosncali
04-04-2011, 10:22 PM
I get about 8mins gve or take a min. With as much as 10 depending on how I drive
ron1950
04-04-2011, 11:42 PM
also the quality of your batteries will have a bearing on run times
gibbies_03
04-05-2011, 12:10 AM
quality is not a problem as I will be running 2 2S Promatch batteries....5000mah 50c...I have been racing rc cars competetively for over 10 years and never once ran another type of battery...do u guys see much of his stuff over on this site?
