View Full Version : run times
rockcrawlerguy
04-03-2011, 03:35 PM
Yes im strongly thinging about ordering a MG boat . but first wanted to know i've read till my eyes crossed about these boats . but what is the run time of the batterys if i leave it stock and throw in some 2s lipo batts ? Just looking for fun in the sun with my son this summer
:sinking-guy:
Nor Cal Chris
04-03-2011, 04:19 PM
With turnigy 2s1p 40c 5000 mah bats and a X642 prop I was getting four minutes thirty seconds runs. I changed all the connectors to 5.5 bullets. This is my first Fe boat and I love it. it has been alot of fun, keep reading all of the good info from the guys on OSE.:thumbup1:
rockcrawlerguy
04-03-2011, 04:40 PM
WOW 4mins ....... i was hoping for at least time for us to get to have some fun but at 4 mins ill have more in battries then i do i the boat for a half day on the lake
dirty
04-03-2011, 07:30 PM
i run about 15-20 minutes per set of batteries in mine.when i charge and balance,they are only putting in about 2500-2800mah.They are 7.4 5000 45c and a set of 40c
rockcrawlerguy
04-04-2011, 08:12 AM
i could handle 15 -20 min run times but 4 mins wow i just cant see how it would be fun to run 4min then charge for hours ..
TheShaughnessy
04-04-2011, 12:21 PM
using turnigy batts from Hk 4s 5000 mah 20/30 c X 2 for 4s 2p and i'm getting 10 min with the ul1 motor. You should get a bit more run time with the stock set up and those batts.
Don't want to discourage you, but if you plan to run a fe boat you are going to need to invest in some batteries. They aren't like a rock crawler that will get 30 min off a little 2200 mah batt. It sucks but it is what it is, if you want to pull the amps you have to be able to supply them.
