View Full Version : Twin cat 32"
nikos222
03-28-2011, 10:14 AM
This is my new cat.
The hull is a hotr 32", and I'm going to make it twin.
First of all i make a carring base. I can use it as an workbench too.
http://img89.imageshack.us/img89/7757/dsc12153.jpg
By nikos222 (http://profile.imageshack.us/user/nikos222) at 2011-01-25
http://img851.imageshack.us/img851/5615/dsc12351.jpg
By nikos222 (http://profile.imageshack.us/user/nikos222) at 2011-03-06
http://img576.imageshack.us/img576/6382/dsc12352.jpg
tunnelvision
03-28-2011, 10:22 AM
Nice, I just picked one up too. Going with the GEICO theme. What is going to be your setup?
nikos222
03-28-2011, 10:27 AM
Then i lay a carbon twill 225gr/m2, inside the hull.
It takes me about three days, trying to do my best.
And...
http://img97.imageshack.us/img97/1496/dsc12474a.jpg
By nikos222 (http://profile.imageshack.us/user/nikos222) at 2011-03-28
http://img860.imageshack.us/img860/6763/dsc12475a.jpg
http://img151.imageshack.us/img151/9341/dsc12477a.jpg
http://img13.imageshack.us/img13/2320/dsc12488a.jpg
tunnelvision
03-28-2011, 11:50 AM
Looks good to me! I think I am going to put fiberglass, may use carbon fiber. Haven't decided yet. Good luck with the build and keep the updates on the progress coming.
nikos222
03-28-2011, 02:07 PM
Thank you tunnelvision.
Next step : COG control, and installation of motor mounts.
I have already 2 x Leopard 3674, 1900 rpm/V, and i'm waiting for the ESC's, 2x180A.
I think that on 5s, maybe it will be better a couple of x442. (L/R)
Stinger shaft: 4mm, flex cable : 3.2 mm.
nikos222
05-30-2011, 06:53 AM
...common base for receiver, battery pack, servo and
temporary esc's arrangement.
http://img820.imageshack.us/img820/3213/dsc12569a.jpg
By nikos222 (http://profile.imageshack.us/user/nikos222) at 2011-04-26
...and the final view at the end of works.
http://img832.imageshack.us/img832/7158/dsc12747.jpg
By nikos222 (http://profile.imageshack.us/user/nikos222) at 2011-05-19
http://img810.imageshack.us/img810/3671/dsc12749a.jpg
By nikos222 (http://profile.imageshack.us/user/nikos222) at 2011-05-30
maker
05-31-2011, 03:22 PM
Now this looks like a real nice build :P how much do somthing like this cost?
Hope to see some pain job or atleast a youtube vid of the boat =)
Keep up the good work!
keithbradley
05-31-2011, 09:12 PM
Looks great nikos! I think the combo you have chosen (1900kv @ 5s w/x442's) is perfect. I have a similar boat.
This should be a fast and fun boat.
FighterCat57
05-31-2011, 09:37 PM
About 24cm from the sponson transom for COG should work well. That's where I've got mine set.
Good to see HOR has the new hull stock. These are the updated hulls which seem to handle better at higher speeds than their predecessors.
I run a pair of K45's for sport. Cheap repair in case of turtle incident. :spy:
nikos222
06-01-2011, 02:25 AM
...early at the morning, Nea Makri, Athens, Greece !!!
http://img59.imageshack.us/img59/9182/dsc12776a.jpg
By nikos222 (http://profile.imageshack.us/user/nikos222) at 2011-05-31
It was the first run for my new twin cat, and i am very happy.
I try : 2 x 4s, 2 x 442 (L/R).
Everything, cool. Everything, dry.
My next run maybe will be with a pair of 1,4 x 43,5mm (R/R) !!!, or 445 (R/L).
Enjoy the sunrise in Greece through the next video.
Thank to all of you.
http://www.youtube.com/watch?v=ka0HbLQTDNM
millzee
06-01-2011, 02:44 AM
:thumbup:nice work mate, well done
nikos222
06-01-2011, 03:14 AM
Hi, Maker.
The total cost is about 600-700 USD, (!!!). :crying::crying::crying:
(Hull, batteries, motors, ESC's, hardware, carbon fiber, etc...)
...but it was realy nice and interest the whole construction.
keithbradley
06-01-2011, 06:25 AM
Looks good and a beautiful pic as well. Why not leave the x442's on and run on 5s? Wasn't that your original plan? Those x442's will hook a lot harder on 5s:thumbup1:
nikos222
06-01-2011, 07:50 AM
Yes. That's true keithbradley.
The first plan was 2 x 442, on 5s. I haven't change that.
But i like to try a pair of R/R props to see the way that it runs,
and i think that it's better to do that on 4s.
kookie_guy
06-02-2011, 07:06 PM
Are you gonna change out the complete flex cable and everything? If your current setup is L/R props, then I'm assuming you are using an L/R flex cable as well.
nikos222
06-03-2011, 02:26 AM
Hi kookie_guy.
Yes, of course. I use a pair of L/R props, with a pair of L/R flex cables too.
Except my usual, I have some of flex cables for clockwise rotation props.
thomaslambo
06-06-2011, 11:40 AM
Hi Nikos222,
Very nice build to be sure, I like the equip setup and very clean job on the carbon fiber.
I have one on order and will start the build in the next week or so :smile:
Also, I noticed a bit of hoping (some refer to it as the "Porpoise Effect") at top speed.
I'll be interested to hear how you adjust for this (I've seen this same hull run perfectly in other videos)?
Regards,
Thomas
FighterCat57
06-06-2011, 02:39 PM
Hi Nikos222,
Regards,
Thomas
Move the COG forward and the porpoising should stop. I have a good number for ya; 24cm from the sponson transom. :cool2:
Dreaded EMS express is late again... Hope to have everything out very soon. They're late by a week!
nosreme722
06-12-2011, 04:22 PM
And...
That looks really nice. How exactly do you do that? Does it involve any prep work? Or do I you just put down some resin/epoxy and carefully lay down the carbon fiber? :confused2: Thanks. :Peace_Sign:
nikos222
06-14-2011, 02:28 AM
Hi nosreme722.
First of all, you have to clean the surface and make it "wild" before lay the carbon fiber.
A very important point is the pre-measurement of carbon fiber pieces.
You have to see before you set the epoxy, the place of each one.
I use an 24h epoxy, so i can fix the carbon and the resin, as mindfully as i want.
But it's difficult to remove it when you have put down the epoxy.
I prefer to lay the carbon fiber first and then put down the resin.
Quite slowly. This way allows you to make your facing without enclose air bubbles.
I hope to help you. Good luck nosreme722.
nikos222
06-14-2011, 03:20 AM
...not so calm sea, not so calm brain too. :biggrin::biggrin::biggrin:
I fit the stingers straight with the sponsons, but the little wave
don't allow me to see more about the seaway.
I call the next video : Dancing cat.
Mind at 1:27", 2:54" and 3:42" and you 'll see.
http://www.youtube.com/watch?v=vOsz05NB_Xo
I have to move the COG forward as FighterCat57 wrote.
I hope that this will be my final trim.
nikos222
06-21-2011, 02:59 AM
...this is the end for my twin cat. So soon.
I had a drop due to not so calm sea. And...
http://img202.imageshack.us/img202/3328/dsc02895ao.jpg
By nikos222 (http://profile.imageshack.us/user/nikos222) at 2011-06-20
http://img856.imageshack.us/img856/4625/dsc02894a.jpg
I'm sad because i didn't have the time to try my 5s batts.
Never mind.
See you soon at a new project.
millzee
06-21-2011, 03:11 AM
sorry to see, it was looking good, sure had plenty of power.
Boaterguy
06-21-2011, 09:54 AM
not very fixable, i feel your pain
now I would like to say some words:
This cat was a very nice woman, she lived like no other, bouncing around and hitting very high speeds and then, all of a sudden:Sinking::sinking-guy:
:bounce:
